John Dunkley
- Jan 1, 1970
- 0
What electronic equipment is it NOT recommended to run off of modified sine
wave inverters?
Appreciate some advice on this.
JD
wave inverters?
JD
John said:What electronic equipment is it NOT recommended to run off of modified sine
wave inverters?
Solar Flare said:Poor power supply, grounding and sheilding techniques.
Solar Flare said:Poor power supply. If you out it
on a DC supply it won't buzz either.
I put my two year old on the street were there were no cars and he
never got hurt.
It must be the cars that cause children to get hit.
Component qualities are rated, partially, by their noise rejection of
power supply inputs and grounding etc..
John Dunkley said:What electronic equipment is it NOT recommended to run off of modified sine
wave inverters?
JD
Solar Flare said:LOL. No, the children was analogy of what you stated, in a attempt to
clarify the poor logical association you made between noise and MSW
PS.
I am sure the amplifier/mixer is designed to reject noise fairly well.
The point is that the MSW is only a factor, in your case, most likely
because of poor grounding, sheilding or equipment design.
This is not
totally the fault of the inverter waveform.
Of course, this is within
reason too. Most equipment aren't gonna' take a square wave PS without
getting hot, or buzzing.
I am suggesting you look at your signal input grounding for picking up
some noise in the grounding conductors from the dirty inverter.
Usually multiple grounding points are the problem where some power is
being carried or induced into a signal ground.
MSW may not be a
problem for the unit at all if clean techniques are used.
Good luck
finding it though...LOL
sonny Power said:Hi JD,
I've been using a Trace DR1524 modified sine wave inverter for about 8
years. I have yet to find something it won't run. It runs computers, TV,
satellite modems, Cisco router, fridges, etc.
About 10 years ago (before sine wave inverters were inexpensive) I did somei've got something that wont run on it... the washing machine in my
motorhome, refuses to start up on a msw inverter output and the circuit
board gets hot,
