Patrick Johnson
- Jan 1, 1970
- 0
I am attempting to drive 8 logic-level MOSFETs (IRLR2905) with an 8-bit bus
switch (FST3244). I have a 300 Ohm resistor in series with the gate of each
MOSFET. Fast switching time isn't a necessity. I also have a 30V Zener
diode connected across the drain-source to handle reverse transients. The
MOSFETs are being used as low-side switches for 12V automotive fuel
injectors (solenoids). I have 4 of these particular circuits built and am
having trouble with all of the MOSFETs failing short-circuit. The first
circuit worked for a little while, the second has yet to fail, and the third
and fourth failed immediately after power-up.
The MOSFETs have a maximum Vds rating of 55V (I am only using 12V) and a Id
happening?
I can't see how I am stressing these parts. Any ideas of what may be20A (I am only using 1.2A). The bus switch has a logic-level output (5V).
happening?
