MOSFET gate current... where does it go?
  • Thread starter Tomás Ó hÉilidhe
  • Start date
Tomás Ó hÉilidhe
Consider an NMOS transistor which is turned off when there's 0 V on
the gate, and turned on when there's 5 V on the gate.
I've been told that a tiny bit of current flows into the gate of a
MOSFET transistor... well where does this current go? Does it come out
the drain, or the source, or does it split between the two?
I
ian field
The gate has a significant capacitance, any current that flows is either
charging or discharging that capacitance.
Eeyore
It comes back out exactly where it went in. Up the gate pin. You have to
both charge and discharge the gate.
Graham
Jim Adney
To add a bit of clarification:
The gate capacitance is between gate and source, so, while you're
charging that capacitance, the charging current is going in the gate
and coming out the source. Discharge is the reverse.
The actual electrons are going in the gate while charging, and back
out the gate on discharge.
legg
The current is needed to form/discharge voltages on the circuit
capacitances.
Current i = dQ/dt Amps, delta-coulombs delta-seconds
Charge q = CV Coulombs Farads Volts
There is also a leakage current, very small, that bleeds through
imperfect insulation in the capacitive structures.
Other losses, in series resistance, will affect energy transfer.
RL
