MOSFETs heat sinked to case power inverter safety.
Magicsmokemaker
Feb 20, 2016
5
Hi all my first post on any site ever! I am fixing a cheap Chinese power inverter 12v DC to 220~240AC it blew a MOSFET on the 240v output side. Now here's the problem the output MOSFETs are heatsinked directly to the aluminium case they are K15A50D by Toshiba in a 220f case i.e. the drain is insulated. I don't have any to hand and they are £10 each from ebay ! I want to swap all 4 output MOSFETs for cheaper alternatives which will be in 220 cases I.e. the drain is connected to the metal mounting tab. Is it safe to use some of that grey coloured rubbery sheet to insulate the MOSFETs from the case?
Magicsmokemaker
Feb 20, 2016
5
I believe it is a good thermal conductor and electrical insulator often sandwiched between a heat source and heatsink grey in colour and often smeared with a white greasy compound. I don't know what it's called and found it twice in power inverters and once on a radio controlled electronic speed controller.
Anon_LG
Jun 24, 2014
453
From what I have read, this is a good thermal conductor and a good electrical insulator. So yes, this will be fine for electrical insulation, I was merely unsure whether you were referring to generic grey foam sheet, this would not have worked. Read here, this is where I checked.
I hope this helps,
Magicsmokemaker
Feb 20, 2016
5
I hope this helps,[/QUOT
Magicsmokemaker
Feb 20, 2016
5
Thanks for the speedy reply could I earth the case somehow in case of insulation breakdown? The case currently has no connection to anything electrically its in mid air so to speak.
Anon_LG
Jun 24, 2014
453
Grounding, this is usually best left to the advice of an electrician, rather than an electronics hobbyist.
I assume that you are familiar with the purpose of an earth return? To enable a more conductive path to earth should the device become hot and the body is touched, ie, an internal short electrifies the metal body with 240 volts RMS relative to neutral, the neutral is connected to earth at the breaker box. A person touching the box should be more resistive than the copper wire going to earth, rendering the device saf(er).
Does the device have any connection to mains? If so it MUST be earthed asap. Whatever you do with earth, I do not think it will protect the FETs. Without the drains connected to the box (the insulator being intact) will the drains be connected to anything?
Is it definetly the drains and not the bodies that are connected tab?
cjdelphi
Oct 26, 2011
1,166
Refine your search (select international sellers)
