MPX or MPXO?
MRW
Hey all, I'm looking at some schematic for an FM IC. There is a pin
that is labled MPX and it is said to be the multiplex output. Is this
the mono signal? I'm just curious.
Peter Bennett
Read the datasheet!
If you expect use to give you a useful answer, at least give us the
part number of the IC, so we can look at the datasheet.
Peter Bennett, VE7CEI
peterbb4 (at) interchange.ubc.ca
new newsgroup users info : http://vancouver-webpages.com/nnq
GPS and NMEA info: http://vancouver-webpages.com/peter
Vancouver Power Squadron: http://vancouver.powersquadron.ca
K
kelvin_cool_ohm
The chip may have a built-in de-emphasis filter block (75uS?)
which also produces some gain to more easily drive a power
output stage. This "MPX" output comes in front of that (and
therefore lacks the gain) but also has the full bandwidth to
carry the added stereo sub-carrier centered at 38KHz.
So, if you want to build a simple, cheap monaural table radio,
you ignore the "MPX" output (or maybe attach the 75uS de-emphasis
network there) and connect the gain block output to a "power"
amplifier chip through a volume controll and you're done.
If you want to go full stereo, you ignore the output gain block,
connect the "MPX" output pin to a stereo decoder chip (usually
available from the same manufacturer), connect dual de-emphasis
networks to the outputs of the stereo demodulator chip then to
dual volume controls and dual "power" amplifier chips.
"Power" amplifier chips might be in the neighborhood of 2 Watts
with 10% distortion for a small table stereo rig!
HTH
Rick
Joseph2k
I suspect that that pin is used to indicate stereo signal carrier detected
and locked. That is what it meant back in the '70's when i was using FM
stereo decoder chips.
MRW
Sorry Peter! The chip is actually a Philips TEA5767. On the datasheet,
it just mentions that MPX is just the multiplex output pin. The chip
also has outputs for the left and right audio channels, but I only want
to use the mono output for now. I guess I can just connect my speaker
drive to either one of the left and right channels.
Thanks!
Similar threads
Replies
1K
Bennett Price
Replies
2K
Sofie
K
Replies
3K
Kevin Walton
K
