Morris Dovey
- Jan 1, 1970
- 0
[ posting from news:alt.solar.thermal ]
The discussion of panels producing both hot air and hot water started
an interesting (to me) chain of thought...
I already use a slat-type absorber in my panels; and I've built one
air/water heating panel that worked passably well at delivering the
incident energy in whatever mix of warmed air/water was called for.
This morning I was speculating on how convenient it would be if the
slats produced electricity in addition to hot air and hot water - and
how if that could be done at reasonable cost, an all-in-one solution
might be possible. Pure blue-sky stuff - but then a couple of
previously unconnected ideas came together: What if my extruded
aluminum slats could be replaced with extruded silicon slats?
I wasn't particularly troubled that silicon isn't a good candidate for
extrusion processes - but then I thought about how the cylinders (from
which solar cell wafers are cut) are produced; and reasoned that
shapes other than round can be produced by interposing a die at the
top of the molten silicon - and that, depending on the "extruded"
shape, might accelerate the process, eliminate the wafer sawing, and
still provide all of the characteristics required for solar cells.
I've put up a web page at the link below with drawings to illustrate
the mechanism and the process. For simplicity sake, the drawing shows
a flat ribbon; but, in fact, the ribbon could take on any "extrudable"
cross section.
More interesting to me is the fact that if incorporated into my
current air-heating panel design (Thank you, Iain!), the photovoltaics
could produce electricity at both faces!
Just thought I'd share...
cross section.
