Multiply 1Hz timebase
Al Klein
Is it possible to selectivley multiply a 1Hz timebase by whole
integers, ie. 2,3,4,5 ... Hz? If so, what would be the simplest way,
without using a microprocessor, PIC, etc.
Al Kein
John Popelish
Al Kein
If you have time to wait for a control loop to settle, you
divide a voltage dependent oscillator by those integers and
phase lock the divided clock to the 1 Hz reference.
A CD4046 chip would do the phase lock:
http://xtronics.com/kits/ccode.htm
Phil Hobbs
John said:
If you have time to wait for a control loop to settle, you divide a
voltage dependent oscillator by those integers and phase lock the
How evenly spaced do you need the pulses to be, and how long a startup
time is acceptable? Direct phase locking will work just great if you
can wait a long time (a minute or thereabouts) for the loop to settle
down, or if you can stand very unequally spaced pulses, in which case
you can acquire lock in one cycle.
Cheers,
Phil Hobbs
Al Klein
Cheers,
Phil Hobbs
I would prefer even spaced pulses, even if it takes a minute. Can you
point me to a suitable circuit?
I am a bit short on resource materials here, and could find nothing
sufficiently explicit online.
Starting with 1Hz, what is the highest practical frequency that can be
obtained without a range selector?
Many thanks,
Al Klein
rebel
There is no practical limit - some people phase lock a 10MHz oscillator to a 1Hz
referecne - but jitter/phase_noise will increase as the multiplier.
