my measurements of amplified ear.
Johan Wagener
here is my measurements taken on the amplified ear with a 16ohm load
(one earpiece) connected and a 1.48V battery used as power source
Q1
E - 0V
B - 0.506V
C - 1.451V
Q2
E - 0V
B - 0.554
c - 1.342
Q3
E - 0V
B - 0.4V decreasing to 0V (after 1 minute)
C - 1.37
Q4
E - 0V
B - 0.63
C - 1.461
I get a very faint amplification of the mic at the output. Increasing
battery to 3V gives better amplification but still only blowing into
the mic or knocking it against the table, and so on.
John Woodgate
I read in sci.electronics.design that Paul Burridge
[email protected]>) about 'my measurements of amplified ear.', on Thu, 12 Aug
2004:
I assume he's referring to this one:
http://www.electronics-lab.com/projects/audio/023/
I built it out (with real components!) of sheer curiosity and it does
work fine. What are you using for D1? The prescribed part or just any
old diode? This fault should be pretty simple to find.
Disconnect Q3 base and D1 from C3, leaving them connected together. Does
it work then? Check that D1 is the right way round. If you are not sure,
try reversing it. You can't damage it by doing so.
Andrew Holme
Q1
E - 0V
B - 0.506V
C - 1.451V
Q2
E - 0V
B - 0.554
c - 1.342
Q3
E - 0V
C - 1.37
Q4
E - 0V
B - 0.63
C - 1.461
Q2 base voltage sounds low and the Q2 collector sounds high. I've
just pushed a 2N2222 and a couple of resistors (R4=100k, R5=3k9) into
a breadboard and I'm getting Vb=0.59V and Vc=0.79V for a 1.5V supply.
Q3 (auto-level control) is off as it should be when there's no input.
Q1 base voltage sounds a bit low but may be OK. You might try
slightly reducing the value of R2, but I would check the circuitry
around Q2 first.
