NEC 1510v Power Supply Pinout
TimCassidy
I got a NEC 1510v LCD monitor that uses a 12 pin DIN for the power
connector. I was wondering if anyone had the schematic for the power
supply and connctor or the schematic for the monitor itself.
Tim Cassidy
bare_foot
I bought one off of ebay, I took back off and found it to be fairly stright
forward. although I have a pic it seems to be washed out. I am still
experminting with the grounds. This is what I am sure of so far. Pins 1&2
= +12Vdc Pins 3&4 -12Vdc Pin 6 is ground. Pins 7&8 second +12Vdc. Pins
9&10 second -12Vdc. Pin 11 is ground. without using grounds and 1 12V
supply you get a pic but only one side of back light works. Using 2 12v
supplys gives a washed out pic because lamps seem to be low light. Mabe
the grounds will make a diffrence. Wlll test later & let you know if any
better. Would realy like to get the power supply schematic..
