NEC PJ3715EN
HI I have a NEC rear projection NEC PJ3715EN YEAR IS 1996 TV and
just want to get advice on troubleshooting it....there was a black bar
on the bottom whacking the TV from behind fixed it so I suspect a bad
solder joints. Also the color is not right I just want steps to
trouble shoot I have experience with electronics thanks
db
Meat Plow
db
You've already trouble shot the vertical. No trouble shooting the color
other than making sure the lenses on the crts are clean and the fluid
inside is clear and the mirror is clean. Maybe get a service manual and
tweak the video settings. 11 years on a projector is getting up there in
years so you also have to consider that one or more of the crts maybe be
weak.
#1 Offishul Ruiner of Usenet, March 2007
#1 Usenet Asshole, March 2007
#1 Bartlo Pset, March 13-24 2007
#10 Most hated Usenetizen of all time
Pierre Salinger Memorial Hook, Line & Sinker, June 2004
COOSN-266-06-25794
H
hr(bob) [email protected]
db
Is Whacking your primary trouble-shooting method? <G>
H. R. (Bob) Hofmann
Sofie
deliper:
I am certain that whacking won't "help" the problem with the color
either....
If you already suspect bad solder joints what troubleshooting advice do you
want?? Your method of troubleshooting is already troublesome.
Fix the suspect solder joints as you surmised and see if that solves the
problem, but don't keep whacking the television or you will have bigger and
more expensive problems.
You may want to go to the website for this newsgroup at
http://www.repairfaq.org/
there, with some search time, you will find a wealth of proper
troubleshooting information that will help you to repair your television.
Best Regards,
Daniel Sofie
Electronics Supply & Repair
