Need a cheap source of 1/4-40 panel nuts
Don Lancaster
John said:
I think the problem is Digikey's search engine. Look at the hardware at
the bottom of page 1659:
http://dkc3.digikey.com/PDF/T071/P1659.pdf
They slipped a decimal place or two on their pricing.
Thanks for the lead, but waaaaay to costly.
Many thanks,
Don Lancaster voice phone: (928)428-4073
Synergetics 3860 West First Street Box 809 Thatcher, AZ 85552
rss: http://www.tinaja.com/whtnu.xml email: [email protected]
Please visit my GURU's LAIR web site at http://www.tinaja.com
John Popelish
What sort of volume are you looking for?
DJ Delorie
Don Lancaster said:
Usual suspects (mouser, small parts, mcmaster carr) no got.
mcmaster carr got.
Machine Screw and Hex Nuts Hex Brass Nickel-Plated 5/16"W 1/16"H
91862A517 1.83 per Pack of 10
About the same as digikey - 0.18 ea in quantity.
H
Homer J Simpson
There has to be an Asian source. Have you asked on
sci.electronics.components?
Jamie
Hmm, that almost looks like the thread size of the mandrel of my dremel
tool?
1/4 inch shaft, 40 threads per inch.
Jim Thompson
tool?
Is there really a 1/4 - 40 size? Man! That's a fine thread for such
a large diameter!
Or did the OP mean 4-40?
...Jim Thompson
RST Engineering \(jw\)
Jim, it is the standard thread for what we call a "miniature" toggle switch,
the kind that mounts in a ¼" hole.
OP, try "Taiway Switch" in Taiwan. Sandy Yen is the contact.
[email protected] They call it a STD-100 nut for the regular hex nut 0.062"
thick. THey also have dress nuts in the same thread if you want it to look
pretty.
It has been a long time since I bought them, but it seems to me that at the
1000 level they were less than a nickel apiece.
Jamie
a large diameter!
...Jim Thompson
i made an extension once to use a dremal 3 jaw chuck in a conventional
drill press, if memory servers, i think i set the lath up for 40 TPI on
1/4 stock.
I've seen 56 TPI , i'm sure there are others.
James Waldby
Jim said:
a large diameter!
No, panel nuts for miniature switches are quite thin, so require
a fine thread. For example, a nut is about .08" thick, with 3
turns of 1/4", 40tpi, thread engagement.
John Popelish
a large diameter!
That thread size is used on miniature toggle switches and
some other panel mount thingies. The fine pitch allows the
nuts to be thin.
Michael A. Terrell
They have a lot of stuff not listed, and do custom. They were one of
the main hardware sources for Microdyne, and we used a lot of weird,
electronics only hardware. We used SS almost exclusively.
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
Rich Grise
tool?
a large diameter!
Or did the OP mean 4-40?[/QUOTE]
No, the big skinny ones that mount pots and rotary switchex by their shaft
bushings.
I seem to have found something in 15/32-32:
http://www.tubeampparts.com/Merchant2/merchant.mv?Screen=CTGY&Store_Code=A&Category_Code=SNB
scroll down about 2/3 page - they've got one called "Knurled switch nut,
15/32-32", for $0.50, and one called "Hex switch nut, 15/32-32", for
$0.25 .
These look very much like the ones I believe OP is talking about; usually
they come with the part.
Cheers!
Rich
Rich Grise
Never mind. This is nowheres near 1/4. I guess my head was in 1967 or
something. ;-)
Sorry.
Rich
