Need Advice How to Repair Plastic Power Switch on Dell 19" Monitor
spippy71
Recently purchased a monitor from eBay. It's a Dell 19" Monitor model
P991 - Sony Trinitron. The monitor was dropped by the courier, and did some
damage to the power button. I've opened the monitor to have a look and.
Exterior button and spring are fine. It's the internal switch that is
damaged. The plastic arm broke away from the switch shaft. The switch is
is soldered onto the "D" board. The Exterior button pushes the arm, which
turns the switch on/off.
Anyone know the best way to reattach the shaft to the switch? Which glue or
cement would work best on these two plastic parts to make a solid bond? I
can post pictures if necessary.
Steve.
Arfa Daily
spippy71 said:
some damage to the power button. I've opened the monitor to have a look
and. Exterior button and spring are fine. It's the internal switch that
is damaged. The plastic arm broke away from the switch shaft. The switch
is is soldered onto the "D" board. The Exterior button pushes the arm,
which turns the switch on/off.
or cement would work best on these two plastic parts to make a solid bond?
I can post pictures if necessary.
Steve.
It's a common thing, and is usually fixable with standard cyanoacrylate
superglue BUT, you MUST splint it as well. The easiest way to do this is to
drill a small hole ( 1 or 1.5 mm ) in the centre of the broken off and
still-attached pieces. Then find a tight fitting piece of wire - I use
enamelled copper wire - and superglue it into one of the holes you've just
made. Now cut the wire off to a length to suit the depth of the hole in the
other piece, put some superglue in the hole, and push the two pieces firmly
together. This will repair the switch shaft as strong as the original. Have
done it many times ...
Arfa
Leonard Caillouet
to drill a small hole ( 1 or 1.5 mm ) in the centre of the broken off and
the other piece, put some superglue in the hole, and push the two pieces
firmly together. This will repair the switch shaft as strong as the
original. Have done it many times ...
Arfa
Another trick that avois the drilling and works well on small pieces is to
just heat up a bit of lead trim from a cap or resistor and melt it into the
parts. A little glue combined with this works well in many cases.
Leonard
Just Another Theremin Fan
The switch is a safety device and should be replaced ONLY
with an approved one.
The people advising super glue and worse are dangerous
cunts who shouldn't be anywhere near electrical equipment.
Of course if you want your house burnt down then go ahead....
Mike Berger
They're just gluing a plastic switch activator -- the switch
itself isn't being touched in any way.
If there's room, I'd use heat shrink around the repaired shaft.
Arfa Daily
The repair to the switch that I and Leonard proposed, is not in the
slightest bit dangerous, and anyone that understands these things would
agree.
You are perfectly entitled to express your opinion, but if you want to do it
here, kindly moderate your language.
Arfa
What other response would anyone expect from a cowboy who
names himself after a used car shyster....?
I'm sure the manufacturers would in no way encouraging your
dangerous antics. I also hope you have informed your house
insurers of what you are doing. In event of a fire you wouldn't
receive a penny (or cent).
There is also no reason why others should have their lives put
in danger by such bodgery.
Arfa Daily
You silly person. Of course in a perfect world, the switch would be
replaced, but this is not a perfect world, and unless the OP is a monitor
repairer by trade, and has a stash of scrappers around to cull a switch
from, the chances of him being able to obtain an EXACT replacement that
didn't require a TRULY dangerous bodge to shoehorn it in, particularly for a
Dell, are slim to zero.
I repeat that there is NOTHING DANGEROUS about repairing the plastic shaft
of a switch, which is operated by a further extension PLASTIC shaft, and if
you think otherwise, then you clearly don't understand very much about
electricity, and the safety of working with it.
Bear in mind also, that the poster didn't actually say that it was a line
power switch. It may well be a low voltage standby switch. Many monitor '
power ' switches are.
Cowboy ? Used car shyster ? Go play some mournful music on your theremin.
Arfa
mikercana1
Where do you get the idea that a switch is a safety device????
Never heard of that before, fuses/ thermal fuses / protection ICs /
circuit breakers and a few more that I have not mentioned.
But nowhere is a switch a safety device unless it is configured as
"Panic switch" "emergency shut off" or some sort of circuitry to shut
off in case of emrgency or fire.
This switch is simply a device to turn on the electronic circuitry on
the circuit board, in this case there is only low voltage going thru
this switch, to a control IC/microprocessor or some similar circuitry.
Although it might sound strange to use krazy glue , it is merely
re-attaching the plastic knob to the switch part itself, nothing else.
In what way would that constitude a safety hazard (taken for granted
that the device is unplugged before doing so).
Not sure in what part of electronic repair you do your work but
comments like yours are definetly not welcome on a newsgroup like this.
Yes if I were to do this repair for a customer, I would certainly
replace it with a new one, but if another techie or someone who figures
that hecan do the job himself , want the easy route in order to save
time/work, then lets help him out.
My2cents.
Ray L. Volts
spippy71 said:
Steve.
If it's a feather-touch control, then a cyanoacrylate will do. The best
1-part cyanoacrylate for plastic, IMHO, is called Plastic Surgery. This is
made, as the name suggests, especially for plastics -- it has a bit of
solvent in it which bites into the material, unlike garden-variety Super
Glues. I used to only find this at Walgreens, but it's been a while, so I
dunno who might stock it now.
There are some good 2-part cyanoacrylates (1 part is an accelerator). These
set up very fast, but Plastic Surgery performs as well as most 2-parters.
If, otoh, the plastic is under more stress, as with a high-current power
switch (cuz ya use more force to push it), you need a less brittle adhesive
for a lasting repair.
A really great product, albeit somewhat esoteric, is called Plas-T-Pair by
Rawn. This is a two-part, resin-based system -- you mix plastic powder with
a solvent and form up the compound. This stuff is perfect for damage where
there's missing bits of plastic, as you can make it as thick or thin as you
like and mold it into whatever shape you want while it's curing, after which
it can be drilled, filed and sanded to match the original part's shape. I
use the liquid solvent by itself for quick welds where the parts meet up
perfectly and there will be little stress on the piece. Where greater
strength is needed, I mix it up and leave a sheath of Plas-T-Pair around the
part in question.
Another specialty solvent I use is called Pro-Weld by Ambroid. It's a 2oz.
bottle of liquid with brush built into the cap. It bonds Styrene, Butyrate,
ABS, Acrylics, etc. This solvent creates solid joints and it sets up super
quick.
For future reference, just in case you dig into a piece of equipment where
you might need to repair a nylon part, forget it! I have yet to discover a
solvent that will work on nylon gears and the like. You might as well try
to weld teflon together. About the only thing available for these is tape.
I know there are some surgical-grade products that claim they work on Teflon
and Nylon, but I'll believe that when I see it.
From every manufacturer that I have ever dealt with! Try learning
a bit more before bodging....
A mains switch *IS* a safety device which should only be replaced
with an approved part.
I am a qualified electronic engineer. I am also a qualified electrical
engineer. And you?
Oh that's ok then. We'll have a low Voltage fire instead of a high
voltage fire!
Carry on bodging chaps!
Ron(UK)
Many manufacturers list the mains switch as a 'critical safety
component' which means it should only be replaced by the manufactureres
part number. Same with safety resistors and fuses - how often does
anyone order exact replacement fuses from the manufacturer of the device!
Many generic mains switches can be found to fit and be utilised, that`s
against the advice of the manufacturer, but it`s up to the engineer who
fits it to make sure that it leaves his workshop in a safe condition.
A repaired plastic part shoudn`t constitute a safety hazard, but
there`s always a chance that someone will bring a case against you in
the event of a subsequent failure involving damage or harm.
Ron(UK)
part number.
Which is what I said.
Any "engineer" doing so would leave himself wide open to legal action.
Possibly criminal legal action if things went badly wrong.
"Real" engineers might remember the Sony TV switch fiasco a few years
back
which resulted in several fires.
"Shouldn't". These jokers are sticking lumps of copper wire up the
middle of plastic shafts. What happens if the shaft snaps again and the
wire is exposed?
Can you imagine the fuss these people would kick up if they put their
Ford car in a garage and got it back with a Vauxhall engine stitched
in it?
Arfa Daily
back
wire is exposed?
in it?
You're getting this out of all proportion, and trying to liken apples to
oranges. And yes, I am a fully qualified electronics engineer, and have been
for more years than I care to remember. The Sony debacle was due to the
switch itself failing as I recall. This had nothing to do with its plastic
shaft. Your point about a " low voltage fire " is pure and utter nonsense.
Perhaps you'd like to explain to us all, with your obviously superior
knowledge of these things, just exactly how a repaired plastic shaft is
going to catch fire - especially one on a switch with a seriously current
limited 5v supply on it. Perhaps you think that the mains voltage is
magically going to jump across to the floating piece of copper wire inside
that 5mm square shaft. The place at which these switch shafts break, is at
least a cm from where any actual power carrying contacts are located, and
usually where the external metal clip and return spring is placed - perhaps
you're suggesting that the manufacturers don't know what they are doing
either when they fit a lump of metal to the outside of the switch. Likewise,
when they fit another dirty great lump of metal to the switch body itself to
make a mounting bracket.
As I said before, in an ideal world, the switch should be replaced, and yes,
I agree that it is usually a designated safety part, but by the same token,
it is often impossible to obtain manufacturer's replacement parts, and a
generic from one of the main component suppliers, has to be used. Are you
seriously suggesting that these are dangerous devices and, if an original
part cannot be obtained, that the piece of equipment should be dumped in the
nearest landfill ?
To examine your car analogy a bit further. We are not talking here about
grafting an IBM chassis into a Dell monitor. We are talking about repairing
one part within the existing chassis. If you took your Rover to the garage
with a braking problem, and they told you that it was a wheel cylinder
problem, but that the original part was no longer available, when they
suggested to you that they could repair your original wheel cylinder, by
redressing its surface, and fitting new seals from a manufacturer of
replacement brake parts, would you tell them no, better tow the whole car to
the nearest scrapyard ? No, of course you wouldn't. You'd have it repaired
and trust that the garage were doing something that was considered safe.
The OP is not a professional repairer, and is not laying himself open to
prosecution for doing something improper to a customer's unit - he is merely
trying to repair a personal item. His house is not going to burn down as a
result - even if the shaft breaks again, and the piece of wire does become
exposed - and how that is going to have any effect is beyond me anyway. You
really are just being pedantic about this.
Arfa
That's stating the obvious! He's a bodger...
OK have it your way. The risk of exposed wires sticking out of a telly
is perfectly safe!
If having good safety standards is "being pedantic" than call me
pedantic!
Arfa Daily
is perfectly safe!
pedantic!
He's not a bodger - in fact we don't know what he is other than a person who
asked a perfectly reasonable question on a newsgroup dedicated to such
items. As far as " wires sticking out of a telly " goes, where does this
come from ? Any fool with two brain cells can see that this ridiculous
statement bears no relevance to anything that's been said in the thread by
any one other than yourself. Clearly, exposed wires sticking out of a
television set is a serious safety issue, and no one in their right mind
would suggest otherwise, but a solid repair to a plastic shaft, on a switch
worked by a plastic extension untouchably secured inside a monitor cabinet,
can by no means be construed as a serious safety issue. Yes, I called you
pedantic ( which is a lot more polite than what you called myself and
Leonard ) and if you insist that this really is a safety standard issue,
then I stand by that. I really don't have a problem with you having high
safety standards, and like most, if not all of the professionals who
frequent this group, I would NEVER advocate anything which would be
generally considered in the business, to be dangerous to life or hazardous
in terms of property damage. I too have high safety standards, but applied
in a sensible way. In 35 years, no repair of mine has ever electrocuted
anyone, or burnt their house down.
Clearly, we're never going to see eye to eye on this, so I think we'll have
to just agree to differ, and leave it to the OP to decide if he considers it
safe to repair his switch, or tries to get a manufacturer's replacement.
Arfa
Leonard Caillouet
who asked a perfectly reasonable question on a newsgroup dedicated to such
switch worked by a plastic extension untouchably secured inside a monitor
cabinet, can by no means be construed as a serious safety issue. Yes, I
called you pedantic ( which is a lot more polite than what you called
myself and Leonard ) and if you insist that this really is a safety
standard issue, then I stand by that. I really don't have a problem with
you having high safety standards, and like most, if not all of the
professionals who frequent this group, I would NEVER advocate anything
which would be generally considered in the business, to be dangerous to
life or hazardous in terms of property damage. I too have high safety
standards, but applied in a sensible way. In 35 years, no repair of mine
has ever electrocuted anyone, or burnt their house down.
have to just agree to differ, and leave it to the OP to decide if he
considers it safe to repair his switch, or tries to get a manufacturer's
replacement.
Arfa
I thought I was the pedantic asshole on this group. LOL. Obviously, this
guy is just trying to demonstrate his superiority by finding something to
criticize. Just let him be, Arfa, and don't waste you time on him anymore.
Like you, I would never advocate kludging a power switch or other safety
related item. Patching plastic parts that are often not available or are
part of expensive assemblies is another matter and is clearly a different
matter.
Leonard
matter.
Now who's being pedantic? One mans "patch" is another mans "kludge"!
Arfa Daily
is made, as the name suggests, especially for plastics -- it has a bit of
These set up very fast, but Plastic Surgery performs as well as most
2-parters.
adhesive for a lasting repair.
with a solvent and form up the compound. This stuff is perfect for damage
where there's missing bits of plastic, as you can make it as thick or thin
as you like and mold it into whatever shape you want while it's curing,
after which it can be drilled, filed and sanded to match the original
part's shape. I use the liquid solvent by itself for quick welds where
the parts meet up perfectly and there will be little stress on the piece.
Where greater strength is needed, I mix it up and leave a sheath of
Plas-T-Pair around the part in question.
2oz. bottle of liquid with brush built into the cap. It bonds Styrene,
Butyrate, ABS, Acrylics, etc. This solvent creates solid joints and it
sets up super quick.
a solvent that will work on nylon gears and the like. You might as well
try to weld teflon together. About the only thing available for these is
tape. I know there are some surgical-grade products that claim they work
on Teflon and Nylon, but I'll believe that when I see it.
So if it was a real question, how about some input from the OP ? Did you
repair the switch in the end, or were you frightened off by some of the
comments ? Did you manage to get a new switch to fit ? Or did you perhaps
take it to the tip and resolve never to buy anything from eBay again, or at
least if you do and it arrives broken, not to dare ask about it again on
here ? Did you feel that the positive or negative comments were justified ?
Just interested to know ...
Arfa
