need data capture, stat analysis, graph display software for PC
colin
I got my PIC producing 10mb data/hr,
now I need something to receive the data
via bluetooth store it and do some statistical analysis
on it and display the results etc.
Before I reinstall my old copy of MSVC C++ I wondered
if anyone knows of a quicker way to get results.
it will probably take me a while to do it with C++ doing all the coms and
windows and maths and graph stuff with mfc,
but ive looked at a few suggestions made like scilab but it doesnt seem to
be all the flexible,
maybe would be realy good to display the final results in 4d or whatever.
there are also some realy hi price packages too,
It might take me longer to wade through all the different ones
then learn it, then find out its not actually so easy to do exactly
what I want after all becuase its not flexible enough.
maybe I need a good C++ library wich maybe even replaces MFC ?
Does anyone have any usefull experience to share ?
basically I have an experiment wich measures the signal rotating at 3rps
and I need to determine direction from this wich will vary cyclicly
over 24hours.
The signal is 1000 times lower than the noise however,
also considerable number of points will be lost due to glitches etc.
The PIC already does some DSP to recover the signal up to this low level.
or maybe is there another forum wich might specialise in this stuff ?
Colin =^.^=
John Barrett
colin said:
over 24hours.
Colin =^.^=
C# has (in the latest release) good serial suppurt, which shouldnt have a
problem linking to serial over bluetooth, and there are a number of decent
and FREE 3D graphics interfaces for C# -- DirectX and OpenGL at the low
level, Axiom and others at a higher level (though those are more scene
oriented)... in any case... C# eliminates the majority of the crap that MFC
or any C++ UI will put you through creating a decent UI
We can take this off group if you'd like to discuss it more.
colin
MFC or any C++ UI will put you through creating a decent UI
thanks, ive not looked at C# yet maybe its time to,
is it similar enough to c++ to pick up quickly ?
Il go look for some online c# references.
its not that far off topic here is it? it is data from an electronic
experiment.
maybe if we get involved in how to combine al the differnt windows
attributes such as scroll copy/paste in one window ..
Colin =^.^=
martin griffith
Would Python be any good at this sort of thing?
martin
W
Wim Ton
colin said:
over 24hours.
Colin =^.^=
If you can get some example code that will write the serial results into a
delimited ASCII file, you can do a lot of processing and graphing in Excel.
Not elegant, but it saves you from learning new packages or languages
Wim
EdV
over 24hours.
Colin =^.^=
Serial Port Import to MS Excel:
http://www.business-spreadsheets.com/solutions.asp?prod=112
I haven't tried this one but it sure looks doable.
colin
Excel.
Wim
Hi, thanks, Ive arranged the data in CSV (comma seperated variables),
as this seemed most widely used, wich comes in through the com4 port.
Im using bluesoleil software on the PC for the bluetoth dongle,
wich works fine with my rs232->bluetooth device except if the
remote system gets power cycled or the PC reset for any reason
it requires manual intervention to restablish the link.
this is quite irritating, all the other classes of bluetooth
devices seem to have options to start automatically.
I could save the data in DOS window with 'type com4>file.txt' but thats not
so elegent.
would be nice to timestamp the data with accurate time too.
atm im just loking at it on a dos screen,
as hyperterminal realy sucks trying to see large chunks of data.
I would need to do FFT on the data to find the direction,
then do FFT on that again to find the cyclcic change in direction,
its probably not that difficult to do,
in fact I would just do it all in the PIC if it had more than 16k of ram!
it has a DSP engine after all ! although ive done it for a limited period
but I realy need to do average over fixed time span rather than just a
running average so need acess to al the points.
I also need to do standard deviation at both FFT steps and filter out any
glitches,
again this isnt to dificult in theory as such,
but im not sure a spreadhseet would cope with 10e6 data points,
I dont realy like the idea of spreadsheets that much tbh,
so ive never realy used them.
Although Ive programmed in C++ for many many years.
Im not sure if the higher level packages would let you reject points of data
or then let you do an FFT on it.
A graphical display of the data would be nice although a final list of the
stats would be ok albeit a bit boring for all the work gone into it, the
graph would at least give me some visual confirmation of the stats too.
Ive just installed the C# from microsoft as it seems to be free !
C# looks promising too.
Colin =^.^=
W
Wim Ton
so elegent.
glitches,
Probably not, but 10e4 is easily done
The nice thing of spreadsheets is, that you can create a graph in half a
dozen mouse-clicks. You can even do crude DFT's faster then learning an
advance math package :p
You can split the processing in several stages:
Remove glitches
FFT
etc.
Each of which are very manageble in whatever language. If you wite the
intermediate results in a CSV, you can have a quick peek if the result looks
halfway decent.
I would suggest to use a standard library for the FFT, so look if there is
one for C#
Wim
John Barrett
martin
techincally you could use ANY language that can cope with the serial
interface, and you can extend python with C/C++ to pull in the needed
graphics capability, but there really isnt a point -- C/C++/C# have the
graphics libraries available off the shelf, as well as loads of code
available for massaging the data before display -- I dumped C++ for C# after
learning Java -- no way I'm going to deal with anything less than a fully
object oriented interface ... python leaves something to be desired there,
and I dont like its indentation-sensitive syntax
John Barrett
experiment.
Colin =^.^=
C# is a blend of C++ and Java -- you wont have any problems picking it up
very quickly -- plenty of example code out there --
http://www.codeproject.com is a good place to start
If you dont want to get hooked in to the MS world -- use Java -- Java3D can
handle the data display and the netbeans IDE is pretty comprehensive (you
can download it at java.sun.com free)
John Barrett
not so elegent.
glitches,
data or then let you do an FFT on it.
Colin =^.^=
Ahh you must have found the "express" version or whatever they are calling
it lately -- that'll get you there :)
feel free to drop email on me if you have C# specific questions.
colin
yep it was quite surprising to find it, I expected it to be limited.
wonder why they giving it for free, must be becuase it ties you into windows
easily with .net.
admitedly it wouldnt let me instal it to my e: drive where I had space
it still decided to try and plonk 1.3gb on my c drive wich is now full,
even though I specified a dir on e:
lets you generate an application in 60 seconds
wich is fine if all you want to do is have a button
wich changes a label to "hello world" when you press it.
I already have com port open so it puts lines from com4 into where the hello
world was
when you preess the button lol, so thats 30% of the way there.
I think il just have to massage the data and interpolate between points wich
I have to reject as glitches.
There are some FFT libraries too thats another 30%,
google came up with one that looked like it would do,
dont know if there are any recomendations available?
although I dont fully understand the FFT terminology used exactly,
I know how to use a DSP to do one though lol.
does the PC have real DSP capabilities wich it uses or just a normal but
fairly quick FPU?
im runing with an AMD64bit CPU.
I have also moved the com port to a new task/thread for reading
and handled acess denied exceptions when it wont open.
atm im looking for a good way to pass the data from the com task to the
processing task.
I gues a stream or a pipe or whatever its equivalent is in c#.net
Il probably find that too, just take a bit more time looking than the other
stuff did so far.
Im sure il find a c# graph library too,
again maybe has some prefered ones.
Colin =^.^=
martin griffith
thanks for that, I'm not "a PC programmer" but quite happy writting
small stuff for 8 bitters, I was just thinking of a simple solution in
the PC world, that would have helped the OP.
martin
John Barrett
windows easily with .net.
hello world was
wich I have to reject as glitches.
fairly quick FPU?
processing task.
other stuff did so far.
Colin =^.^=
FPU based -- no on-board DSP :)
for the data transfer -- look at the System.Collections.Generic namespace --
create a class that represents a block of FFT ready data.. have the com port
thread assemble the block, and when ready.. push the block into a typed
queue (generics are like C++ templates.. let you create collections of typed
objects with full compile time type checking)
use the "lock" statement to wrap your push and pull methods so that access
to the queue is serialiized, and optionally create an event to notify the UI
code that there is a block of data ready to process. (or use a timer to poll
for data -- whatever you are comfy with) Note that C# gets pissy when you
attempt to access UI elements from a thread other than the one that created
the UI -- look at delegates and the Invoke method to work around the issue
if you need the background thread to access the UI.
You might want the FFT and any other data crunching on the com thread or
even a seperate cruncher thread so the UI just has to deal with displaying
ready-to-render data.
sounds like you are off to a running start, though !! glad to see you are
slipping into C# so quickly :)
(ohh and the Mono system for *nix will run dotNet code -- so you really
arent all that locked in to MS with C# any more )
colin
namespace -- create a class that represents a block of FFT ready data..
have the com port thread assemble the block, and when ready.. push the
block into a typed queue (generics are like C++ templates.. let you create
collections of typed objects with full compile time type checking)
The com thread needs to be real quick as it needs to timestamp each line to
10ms resolution if possible,
itl just do that and also split it into seperate chanells for fft data and
housekeeping data, errors etc.
and save it in files. the PIC is short of a RTC with proper time.
the fft thread has to read any old data stored in files then add the new
data from the com port
thread then do number crunching every so often on the data collected so far.
UI code that there is a block of data ready to process. (or use a timer to
poll for data -- whatever you are comfy with)
thanks that 'lock' sounds like what I need,
of course I could just use the files to transfer data ..
just make them each hold chunks of 10 minutes or so they are finished
with by the com thread before the fft thread gets to them,
but the lock would make me free to make them longer.
im sure theres probably simple pipe type class wich uses the thread lock.
Note that C# gets pissy when you attempt to access UI elements from a
thread other than the one that created the UI -- look at delegates and the
Invoke method to work around the issue if you need the background thread
to access the UI.
yeah thats just like mfc, it used temp data objects wich arnt garanteed to
not have been destroyed when other threads are running.
Cool thanks, yeah I get up to speed real quick I gues,
but only if i can find the enthusiasm though and then thats either on or off
with little inbetween
I just bualk at the idea of trying to go through loads of new things trying
to evaluate them,
ive tried that before and it can realy suck.
Colin =^.^=
John Barrett
to 10ms resolution if possible,
far.
off with little inbetween
trying to evaluate them,
Colin =^.^=
I was thinking more realtime than logging to files -- think about having the
com thread pump the data to a writer thread in that case :) sounds like you
may end up with 3 or 4 threads sharing the load, which is a good thing
IMO -- as threads that are idle dont take resources -- event driven makes
life much simpler
might also look at the background worker class -- it encapsulates a lot of
the crap for starting a worker thread as needed and getting notified when it
completes
colin
the com thread pump the data to a writer thread in that case :) sounds
like you may end up with 3 or 4 threads sharing the load, which is a good
thing IMO -- as threads that are idle dont take resources -- event driven
makes life much simpler
it completes
I dragged that very class right of the IDE toolbar into the project.
same with the serial class.
3 or 4 threads is probably about right.
I need to save the data regardless anyway.
I could have the analysis done after all the data is gathered but realy
would like to see how well its progressing so i can catch anything
going wrong and not waste days colecting duff data.
I found a Queue wich can transfer objects between threads
took me a while to figure out I needed to actualy create an instance of it
with new.
works but I gues I need to protect it with lock and I need to have something
to wait on.
I tried the messaging thing but it complains its not installed on my pc.
the sockets seem primitive as they stil rely on byte streams,
although come to think of it that is actually all what I have anyway.
cant beleive they havnt put in some sort of decent inter thread message
queue.
although theres a few examples of how to implemet one about.
cant even send them as simple windows event messages like with mfc.
Colin =^.^=
John Barrett
with new.
something to wait on.
queue.
Colin =^.^=
ya -- they dont make the collection classes thread-safe for performance
reasons -- they figure anyone that needs it thread safe can create a wrapper
class derived from the collection and override the key methods to implement
locking
If by messaging, you are talking about MSMQ -- thats a bit overkill for
this -- just create a protected queue class and go from there -- its easy
enough to add events to the class so that the reciever can get notification
when data is available. You dont need to "wait" on anything -- just have
each class set up its event handlers in the constructor, and leave the
instance to sit until an event occurs.
"simple windows event messages" -- why get the OS involved with the
notifications ?? I can understand how you would feel that WM is simple given
your MFC background, but you are pushing your message out of process when it
really doesnt need to. using WM like that was a "lazy" solution for people
that didnt want to write thread safe code, or didnt undestand mutual
exclusion locks and syncronization. Not that I didnt use it when I was
writing win apps in C++, but it really wasnt the right way to solve the
problem :)
Re: sockets -- yes they are byte streams at the low level -- all IO is --
even disk -- you can wrap them in a stream reader if you want a string/line
oriented interface, or make your own reader to de-block the data any way you
want :)
colin
wrapper class derived from the collection and override the key methods to
implement locking
this --
ah ok I guesed it was something a bit more complicated.
done that.
its easy enough to add events to the class so that the reciever can get
notification when data is available. You dont need to "wait" on
anything -- just have each class set up its event handlers in the
constructor, and leave the instance to sit until an event occurs.
erm easy if you know how I gues, I didnt come accross events so far,
im using the workerthread things dragged from the toolbox so I kind bypased
the constructor details.
I used System.Threading.AutoResetEvent, to wait for the queue to become non
empty,
wich is actually easy enough.
given your MFC background, but you are pushing your message out of process
when it really doesnt need to. using WM like that was a "lazy" solution
for people that didnt want to write thread safe code, or didnt undestand
mutual exclusion locks and syncronization. Not that I didnt use it when I
was writing win apps in C++, but it really wasnt the right way to solve
the problem :)
but it sounds like these event handlers you mention before do the equivalent
of
what the old win32 messages do wich is what I was looking for,
but just with the strong type control thats needed ?
windows messages wasnt realy a lazy solution as they were the underlying
fabric of mfc.
they were not only used to talk from task to task but mostly within the same
task.
although there was the problem of ensuring what was responsible for the
allocated memory
wich c# takes care of.
I find it hard to beleive the functionality of sscanf isnt in c#
I found loads of articles of people trying to convert c++ code into c#
and loads of people trying to answer but getting tied into knots with saying
you just use
regex or tryparse without realy knowing how to exactly,
but these are either rather low level or overkill.
trying to parse my variables wich are seperated with a variety of delimiters
for clarity
is irritating without an equivalent.
I tried to make a function template but it wouldnt let me access the right
TryPars member from the template. So i have one for each type. it works
anyway.
thanks
Colin =^.^=
John Barrett
done that.
bypased the constructor details.
non empty,
equivalent of
fabric of mfc.
same task.
allocated memory
saying you just use
delimiters for clarity
anyway.
thanks
Colin =^.^=
To create an event
1. create a "public delegate <method prototype>;" outside the class that
will have the event... inside the class -- add a "public event <delegate
method name> <event name>;"
2. any place in the class where you want to fire the event, add "if (<event
name> != null) <event name>(delegate params);"
3. in any class that you want to handle the event, add "object.<event name>
+= handler;"... the IDE will create the handler stub for you if you hit tab
twice after the +=
the delegate defines the parameters that will be passed, the event statement
defines the variable that will contain the list of handlers to be invoked
when the event is fired. Since delegates are typed, you can pass any
number/type of parameters that you like -- no limitations :)
Re sccanf == ya -- that doesnt really fit into the java/c# paradigm --
you've probably already found this or something similar -- but here is a
regex based sccanf for c#
http://www.codeproject.com/csharp/CsScanf.asp
