Need Help for Temperature Control System
Thomas Ritche
Hi All
I want to construct a Temperature Control System myself.
I want to use a Thermocouple to sense the Temperature.
(Thermocouple generate 0 mv at 0 degree celcius and
150 mv at 300 degree celcius)
I want to control the temperature range between 0 to
300 degree Celcius.
I want to use analog system and controls.
Can any tell me about a web site which showing a complete
circuit diagram of Temperature Control System which I want.
Thomas Ritche
F
Fred Abse
I want to construct a Temperature Control System myself. I want to use a
Thermocouple to sense the Temperature. (Thermocouple generate 0 mv at 0
degree celcius and 150 mv at 300 degree celcius)
Those temperatures are actually the difference between the "hot" and
"cold" junctions. This means that if the temperature you want to measure
is 0 Celsius, and your instrument (where the "cold" junction normally
lives) is at room temperature, say 20 Celsius, you won't get zero, you'll
get minus 20 reading. You need to incorporate circuitry that will
compensate for the "cold" junction temperature.
temperature range between 0 to 300 degree Celcius. I want to use analog
You could just use an op amp to amplify the thermocouple voltage to a
level where you can use a comparator against a voltage derived from a
calibrated potentiometer. That'll give you simple on-off control, or
replace the comparator with a summing amplifier which will give voltage
proportional to deviation from set point. If you want integral and
derivative terms, things get complicated. There are (or used to be, it's
been a while) devices that do the whole CJ comp / PID thing on one chip.
Can any tell me about a web site which showing a complete circuit
Just Google. You'll probably find ready made controls which are quite
cheap.
John Popelish
Thomas said:
Hi All
300 degree Celcius.
Here is a start in understanding how to get a linear temperature
reading out of a thermocouple:
http://www.national.com/an/AN/AN-225.pdf
A PI controller is little more than an inverting opamp with an R and a
C in series in the feedback path. Of course the values have to be
tuned to match the system being controlled.
The output depends entirely on what you are controlling.
Bob Huish
DS1620
Measures temperatures from -55°C to +125°C
in 0.5°C increments; Fahrenheit equivalent is
-67°F to +257°F in 0.9°F increments
He wants 0 to +300C
Any other ideas?
I need one to measure a solar cooker project.
Bob Huish
