Need help in display connetion with pcb
sanoop
Jul 2, 2017
this display is from my treadmill display console. i think the rubber strip which connects the lcd with pcb is damaged .
any alternative methods for the connection ..
thanks in advance
kellys_eye
Jun 25, 2010
6,512
No.
That's what's called 'zebra strip' but it is available online if you search.
It rarely goes 'wrong' - most faults occur when the mating surfaces are contaminated in some way. Give all surfaces that meet (both sides of the strip and the two plated mating surfaces) a thorough clean using IPA (iso-propyl-alchohol) and make sure the correct pressure is exerted between the two - this part is important.
If you over pressure the joint you'll damage the LCD.
