Need help on series circuit
btsmith
Jul 4, 2018
3
Need help solving the following for "R". It seems like not enough information to solve?
Kabelsalat
Jul 5, 2011
198
Yes, you got everything you need.
One method is to makke out the formula of voltage divider - what voltage over R with respect of the value of R.
Then insert this formula (replace by it where "R" would be) in the formula where you would solve the Wattage with respect of R/inserted formula.
Then you reverse the formula so you get R by respect of W.
Ylli
Jun 19, 2018
411
P = E * I
P = 24 [given dissipation of R]
E = 24R/(R + 6) [voltage divider to determine voltage across R]
I = 24/(R + 6) [Current through the loop per Ohms law)
Substitute into the first equation and solve for R. It does end up giving you an easily solvable quadratic equation.
Kiwi
Jan 28, 2013
507
"quadratic equation" crikey that takes me back over 40 years to my high school days.
Might have to try solving this to see if I still remember how to do them.
Here's a way that doesn't require any magic.
Assume R=0. What is the current and then the total dissipation of R1 and R2.
Power dissipation is proportional to current squared, and this pair of resistors just happens to dissipate 4 times the power that the target R needs to dissipate.
Given that this means the current would halve to make this pair of resistors dissipate 24W, what does that tell you about the value of R and the dissipation it would have?
Simple approaches like this (whilst not generally applicable) can often work well for problems that are designed to have "nice" solutions. At worst, they provide a method to estimate a value or double-check your answer.
btsmith
Jul 4, 2018
3
P = E * I
Got it, thanks for the help.
btsmith
Jul 4, 2018
3
Thanks for the help
