Need parts for Solomon Solder Station
F
Fred McKenzie
A friend has a Solomon SL-20 Electronic Soldering Station. It has an SL-1
iron with a broken tip. He obtained it from a local company that went out
of business.
Searching the web, it appears that Solomon is popular everywhere else in
the world, but not in the U.S. Does anyone know of a U.S. source for
Solomon parts?
Or, is anyone familiar with Solomon, and know if there is a commonly
available tip that is compatible?
Fred
Larry
Fred McKenzie wrote:
: A friend has a Solomon SL-20 Electronic Soldering Station. It has an
: SL-1 iron with a broken tip. He obtained it from a local company
: that went out of business.
: Searching the web, it appears that Solomon is popular everywhere else
: in the world, but not in the U.S. Does anyone know of a U.S. source
: for Solomon parts?
: Or, is anyone familiar with Solomon, and know if there is a commonly
: available tip that is compatible?
: Fred
Hi Fred,
Look here http://www.a1parts.com/solomon/
Larry
g. beat
of business.
Solomon parts?
Fred
Fred -
Hopefully I can help you.
Sorny Roong Industrial Co., Ltd (Solomon) - based in Taiwan is one of the
largest OEM suppliers of soldering stations - BUT you are correct individual
parts and tips can be a BEAR to get at times.
http://www.soldering.com.tw/cgi-bin/companyfn/com_profile_lst.pl
Remember that Solomon is an OEM manufacturer -- so they rely upon the "Brand
Name" companies (e.g. Circuit Specialists, Elanco, Tenma) in the USA to
worry about consumables for "end user" or " consumers" !!
Solomon SL-20
http://www.soldering.com.tw/cgi-bin/productfn/pdt_detail_lst.pl?ProdID=8
Now, I just so happen to repair a Tenma (Solomon) unit last year.
So here is the information you need:
1. The heater and thermocouple are integrated in this design -- so IF one of
the other fails -- you need a new heater/probe assembly !!!
(The newest Weller WES51 station uses this same concept to compete and save
2. The individual parts, while listed on the Solomon web site in Taiwan, are
non-existent with suppliers that I called. Why? They are the same price or
slightly higher than purchasing and entire NEW IRON !!
3. For my Tenma repair, I was able to call MCM on their 800 and they cross
referenced my Tenma base unit (Solomon SL30) with their internal part number
for the correct iron (cost around $ 6 ). I did extensive clean-up on the
unit (it was used daily in a radio/TV shop) -- and replaced the AC line
fuse -- with one of the correct value (they had a 5 amp in for a 1 amp
fuse -- no wonder it failed) !!!
FOR YOUR REPAIR, Check with Circuit Specialists --
I think Solomon used the same iron for the SL10, SL20 and SL30 stations
This is most likely part number SL24V at Circuit Specialists ($10.50)
The iron has a 5 pin DIN connector for a plug - right?
http://www.circuitspecialists.com/prod.itml/icOid/6390
Selection of tips
http://www.circuitspecialists.com/level.itml/icOid/2494
Greg
w9gb
g. beat
of business.
Solomon parts?
Fred
Circuit Specialists are in Arizona, and I already provided you that
information.
C&S Sales in Wheeling, IL (usually have Elanco products) -- they do list
tips -
and MAY also have the iron (did not list on web site)
http://www.cs-sales.com/sl30.html
MCM Electronics (Tenma brand name) - enter part number (below) for fast
search
http://www.mcminone.com/
REPLACEMENT SOLDERING IRON FOR 21-7930 (SL-10) AND 21-7935 (SL-30)
MCM Part #: 21-7936 ($ 9.29)
Availability: 291
a.. Direct replacement for iron supplied with Tenma #21-7930 and 21-7935
soldering stations
a.. 24V, 48W heating element with internal temperature sensor
a.. Heat resistant silicon cord
a.. Supplied with conical tip (#21-7980)
gb
F
Fred McKenzie
Greg & Larry-
Thanks for the speedy responses. I'll relay them to my friend.
Fred
K4DII
