O
oldave
- Jan 1, 1970
- 0
I have gone through so many "threads" and discussion forums to try t
find a schematic for the Sony STR DE535???
My problem is I was Playing my Sony Stereo,and switched to CD Mode,an
it DID play for about 2-Seconds and went completely "Dead"*except
couple of "Panel" lights,BUT NO "Display Screen" lite up???I opened i
up to find it had "Blown" (2)both 8-amp fuses on the power suppl
board.I replaced these fuses, then JUST PLUGGED-IN THE AC Cord into th
wall & "POP" went the 6.3-amp fuse on the "Standby-Power-Board"????
tried it wasting 3 fuses then gave up.
I plulled the "black-cap" off of the Relay to see if it were makin
contact after being Plugged-In to the AC.The 6.3-amp fuse "HELD" eac
time after that,UNTIL I "Closed" the points on the Relay and i
"Popped" the fuse each time when I tried to close the Points???
It would appreciated greatly any help/advice or suggestions on m
perplexing problem????
Good Luck & Good Music...
oldav
oldav
