need simple microphone pre-amp opamp circuit
I have to throw together a simple op-amp based electret microphone
pre-amp circuit on the road (limited access to hardware) - yes I feel
like Mcguiver.
I have access to a LM357 op-amp that I need to use with a single 6v
supply.
Anyone have a simple circuit that will work with a single supply
powered op-amp?
Phil Allison
like Mcguiver.
supply.
** Don't you mean the LF357 ?
powered op-amp?
** Although this op-ap is not spaced by Natsemi to operate with less than
+/- 5 volts supply - it will still function with reduced specs with a 6
volt single supply.
Just use a standard inverting amp stage and bias the + input to 3 volts.
Suggest the input resistor be 3.9 kohms and the feedback a 250k ohms pot.
........ Phil
W
Walter Harley
like Mcguiver.
supply.
powered op-amp?
Google for "opamp electret mic preamp" (without the quotes).
