need to convert 12 volts to 6 volts @ about 4-6 amps
I don't know if I am in the right category - if I am not somebody
please direct me there. What I am looking to do is to use a 12volt
car battery to run 6 volt electrical motor. It used to use 6volt 4
amp/h battery. I wold like to find out if there is a way of convering
the power from car battery without waisting any juice. I think I can
just take some wire and wrap it into a coil and run my positive
through that, but then I will be loosing the juice. It might not be
enough to worry about, but, I would like to know the specifics. there
might also be another way - which I don't know about. I would also
like to keep it cheap if possible.
please if you have any ideas -let me know. thanks
N
Nobody
The standard mechanism for efficiently controlling power to DC motors is
pulse width modulation (PWM). IOW, you turn the current on and off rapidly.
The alternative (dropping voltage across a load resistor) is going to
waste 50% of your power. If the motor draws a lot of current, you would
need a high-power resistor, which may well cost more than the components
required for PWM.
Essentially, you need:
1. A transistor (bipolar or MOSFET) which can take the motor current.
2. A diode with the same current rating.
3. A square wave oscillator, typically running at a few KHz (for a fixed
ratio, a 555 is the obvious choice).
Connect the motor between the +12V supply and the collector or drain of
the transistor. Connect the emitter or source to the ground (0V) line.
Feed the square wave to the base or gate (for a bipolar transistor, via a
resistor). Connect the diode across the motor with the *cathode* to the
+12V supply.
If you can provide the specifications of the motor (preferably the
current; failing that, the power), someone may be able to recommend
specific components.
John B
This question should be in sci.electronics.basics.
DigitalRaptor
If you are needing something in a 12 volt system, but need to pull 6
volts off to power something else, couldn't you just use two 6 volts
batteries wired in series to run the 12 volt stuff, but then tap
directly into one of the 6 volt batteries to power the 6 volt motor?
