Need to design precision 5mA constant current source (wide temp range).. need help
stevo
I need to design a 5mA constant current source for a Wheatstone bridge application. The problem is the source needs to be +- 3% accurate and
hold that accuracy over a -40 C to +85 C temperature range.
I have thought about using a simple FET CCS, but don't have much
experience and am not sure if I can make it accurate enough.
Can any of you more experienced guys point me in the right direction?
Thank You
Stephen
Ohter info : V avalible +15V; bridge resistance ~ 850 ohms
John Fields
Thank You
Stephen
John Popelish
stevo said:
Thank You
Stephen
Are you sure that a constant voltage across the bridge would not
improve its accuracy?
stevo
I currently have the end of the bridge connected to ground, but I
suppose it wouldn't have to be.
stevo
The spec sheet for the bridge has the following:
Sensitivity tempco:
Vbridge= 8V (constant voltage) 0.3 %/C
IBridge = 5mA 0.06 %/C
So, it appears that the bridge is more stable w/ the constant current.
John Popelish
Sensitivity tempco:
But those values are very different excitation levels. 8 volts across
850 ohms gives an excitation current of 9.4 ma, and a bridge
dissipation of 75 mw, while 5 ma of bridge current gives a bridge
dissipation of 21 mw. A 4.25 volt excitation would be more equivalent
to the 5 ma excitation, and may improve on its stability.
