Hey guys,I have an issue. My expertise is in welding and fabrication, not electronics, and I have a project where I need to power some UV lights with a battery power supply.
The led strip lights are 24v with 240 diodes per meter I believe, so I matched them with a power brick( Talentcell 24v)
For starters the power supply is massive. And second, the led strip becomes very hot fairly rapidly when powering on.
Any recommendations on a smaller power supply that’s battery rechargeable via usb?
Any of you able to answer as to why these things are getting so hot? Are they being overdriven?
Any thoughts/ suggestions would be appreciated.
Here are the specs and a photo.
One chart should be the LED specs, the other is the Talentcell 24.
