Notebook LCD replacement
H
hemyd
The company for whom I work uses LCD displays by two or three manufacturers
(such as Hyundai and LG), the same displays being used over a very large
range of laptops. What I'm saying is that there is a good chance you will
find a compatible display. Naturally both displays should be the same size
and both should have the exact same sockets and plugs for the flat signal
cable and the inverter cable. Both should have the same maximum resolution.
I am not familliar with many brands of laptops and how to get at the
components. Unfortunately it's often not easy to work out if some part of
the cover snaps in, slides in or is screwed in. The sound of cracking
plastic is not a nice thing.
If or when you do get access to the actual panel, and you find that your
replacement display is compatible, be careful with plugging the flat signal
cable into the lcd panel socket. Slide it in gently, parallel. It is easy to
bend a pin, and it would be a dog of a thing to straighten it.
Good luck.
Henry.
F
Ferney
So, I've managed to destroy the screen on a Toshiba Satellite Pro 4300 and
I'm wondering what my options are for replacing it.
Now, I know that I can get another screen from another Satellite Pro 4300
and just swap them (although apparently even that can be difficult, as
they often use different screens within the same model family), but I'm
having a hard time finding one and I want to keep the repair as cheap as
possible.
Wondering if anyine knows hwether it is possible to get into the screen and
actually replace the LCD panel. I have an HP N5420 that I destroyed, but
the screen is still intack. What's the chance that I can swap the good
panel for the broken one? Better said; what's the chance that someone who
knows what they are doing can swap one panel for the other?
If anyone can provide any opinions or guidance on this situation, it would
be much appreciated.
Thx,
Andrew
James Sweet
possible.
Thx,
Andrew
If the panels themselves are identical then yes you can swap, if not then
no, no chance. Best bet is to look on ebay for a dead laptop with a good
screen.
Barry Watzman
Of course you can just replace the LCD panel, that's what's usually
done. But it has to be the same panel, and the chances are that no 2
laptops use the same panel (that's actually not true, but if two do use
the same panel, it's just by "accident"). There are far too many
different LCD panels, and it's not unusual that a given panel is only
made for a few months and then gone forever.
jimbo
possible.
Thx,
Andrew
I found an exact replacement for a Sony laptop on E-Bay. But, be
careful. A 13 inch LCD is not necessarily a 13 inch replacement. I
opened up my laptop and got the model numbers off of the panel and
matched model numbers before I bid.
Good luck, jimbo
Joe
The best way is to open up the display and look for the model number and do
a search with that.
You probably end up with a list of computers that use the same panel and
then you can search again for those laptops, etc.
Good luck.
Jan
Finland
Mr. Fedora
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
4300 and I'm wondering what my options are for replacing it.
Pro 4300 and just swap them (although apparently even that can be
difficult, as they often use different screens within the same
model family), but I'm having a hard time finding one and I want
to keep the repair as cheap as possible.
screen and actually replace the LCD panel. I have an HP N5420
that I destroyed, but the screen is still intack. What's the
chance that I can swap the good panel for the broken one? Better
said; what's the chance that someone who knows what they are doing
it would be much appreciated.
Thx,
Andrew
Try this:
http://www.impactcomputers.com/toshiba-satellite-pro-430cds-parts-disp
lay-hardware.html
I have no interest in this vendor other than I have purchased and
repaired laptops with their parts. YMMV
-----BEGIN PGP SIGNATURE-----
Version: PGP 8.0.3
iQA/AwUBQfNtZ2HVJgr/iYLAEQKJhACeJ+LFqM9TuzvLKzJCt96q78Hd204AnRza
3UlkqidU2ACu7f3qTia0HffQ
=SwPm
-----END PGP SIGNATURE-----
