NPN Common Emitter Bias
dgc
Can an NPN transistor in a common emitter configuration be safely biased for
standing DC current WITHOUT having an emitter resistor in the circuit, i.e
emitter directly tied to ground? I'm trying to accomodate a 12 volt peak
swing on the collector with only a 12 volt supply available. Any emitter
resistor obviously lowers the peak voltage the collector can handle, while
remaining linear, so I am trying to avoid using one.
Thanks.
John Popelish
Thanks.
You can use collector voltage feedback, instead.
dgc
Thanks John. I have seen collector voltage feedback modeled in a text I am
reading. However, just for my education, could a transistor be biased for
standing DC current with a direct ground connection on the emitter, without
damaging the transistor.
Tim Wescott
Thanks.
It can be done, but it gets complex. "Radio Frequency Transistors --
Principals and Practical Applications" by Dye and Granberg has some
examples.
John Popelish
If the transistor is kept at a fairly constant temperature, and the
bias is carefully set, the transistor is unlikely to be damaged, since
in a class A operation, the worst case power dissipation occurs at
zero signal. The real problem is whether the bias point will stay
centered well enough for the required signal swing without clipping.
If the temperature changes more than a few degrees, all bets are off.
Transistors are pretty good thermometers.
A simple collector voltage bias involves connecting the base divider
to the collector, instead of to the supply, with the top resistor
value dropped to account for the lower voltage across it.
Pooh Bear
Not easily.
Any objection to an IC if it's small signal ?
What's the application ?
Graham
Pooh Bear
Lower value resistors reduce the beta ( current gain ) sensitivity too.
Of course this configuration applies negative feedback - No idea if that's an
issue for the OP.
Graham
Andrew Holme
Thanks.
I've seen a circuit where the NPN is biased using a PNP transistor.
From memory, it was something like an RC low-pass filter from the NPN
collector to the PNP emitter; with a potential divider setting the PNP
base voltage; and the PNP collector feeding bias to the NPN base. I
think it was a wideband RF buffer stage in a Marconi signal generator.
I'll check the service manual when I get home tonight.
F
Fred Bloggs
This can be done any number of ways but your question cannot be answered
without knowing the frequency range of the signal to be amplified, the
required gain of the circuit, the loading, and the source
characteristics. Local feedback is not going to cut it since the
transistor gain goes to zero at cutoff and saturation.
W
Winfield Hill
Tim Wescott wrote...
examples.
I don't have that book, but many wideband linear RF amplifiers I've
worked on used a current-sensing resistor in the collector RF path,
with a little servo circuit to establish the average value of the
base current. This is easy to do with just a few transistors. The
sense resistor need not drop more than 200 to 400mV.
I
Ian Bell
for standing DC current WITHOUT having an emitter resistor in the circuit,
i.e
Thanks.
Yes, but you need feedback of a different sort. My ascii art is crap so I
will describe one type of circuit. Collector resistor to Vcc, emitter to
gnd. Resistor from collector to base. Resistor from base to gnd. Collector
volts is essentially vbe multiplied by the collector/base base/gnd resistor
ratio. This sets both ac and dc gain. You can separate ac gain by slitting
the collector/base resistor into two equal parts and decoupling the
junction to ground.
HTH
Ian
Jim Thompson
junction to ground.
HTH
Ian
AND: TC of output DC bias point = -2mV/°C * DCGAIN
...Jim Thompson
Andrew Holme
They used lots of variations: always with a resistor between PNP collector
and NPN base; often with a large capacitor from PNP collector to ground;
only sometimes with a capacitor from PNP emitter to ground; and sometimes
with a small NPN emitter resistor. None are anything like rail-to-rail
output. Sometimes there's a diode in series with the potential divider -
presumably for temperature compensation. I also found an example where they
used an NPN instead of the PNP, but enough said.
This is from a 500-900 MHz first LO drive circuit:
.------------------------o------- +10V
| | | 100-ohm
| | .-------o-------o
o------| --- 1n C|
| |\ | C| L
.-. | | C|
| | .-. GND |
'-' | | o-------- out
| | | 1k5 |
GND | |
in --------------o-------------|
GND
created by Andy´s ASCII-Circuit v1.24.140803 Beta www.tech-chat.de
I
Ian Bell
Quite right, and probably the reason it is rarely used. In simple
applications where temperature range is limited it may not be a problem.
With a 12V supply and a 6V collector voltage the temp co is about
20mV/degree which over a 20 degree range is just 400mV.
Ian
John Larkin
Ian
Well, just run the low side of the bottom resistor to a negative
voltage. That's a great way to bias gaasfets, too.
John
I
Ian Bell
John
I suspect if the OP had a negative voltage available he would want the
output to swing all the way down to it ;-)
Ian
W
Winfield Hill
Andrew Holme wrote...
| | | 100-ohm
| | .-------o-------o
o------| --- 1n C|
| |\ | C| L
.-. | | C|
| | .-. GND |
| | | 1k5 |
GND | |
GND
The circuit has three problems, all easily fixed. First,
the bypass cap should go across the sense resistor, etc.,
because the goal is to get a constant base-bias current
to the RF transistor, unaffected by supply fluctuations,
RF currents, etc. Second, we don't want the servo-loop
gain too high at high frequencies, so some PNP emitter
resistance is in order. Third, we'd like to reduce the
wasted voltage drop across the sense resistor, yet avoid
tempco issues with the PNP, so we need a tempco-matching
transistor. Here's the result of these changes.
.. .---------------------+----+------- +Vcc
.. R1 _|_ Rs
.. 250mV --- 200mV
.. v\| .--/\/\--+----+
.. |---, | 50mV |
.. /| | |/v |
.. +-----+----| C|
.. | |\ C| L
.. R2. | C|
.. 5mA | |
.. etc | |
.. | | +-------- out
.. GND | |
.. RF IN------+-----------|
.. |\v
.. GND
. R1 _|_ Rs
. 250mV --- 200mV
. v\| Q3 .--/\/\--+----+
. |---, | 50mV |
. /| | |/v |
. +-----+----| C|
. | Q2 |\ C| L
. R2. | C|
. 5mA | |
. etc | |
. | | +-------- out
. GND | |
. | Q1 |/
. |\v
. GND
Gee, I thought I'd invented this scheme, used in a 920MHz RF power
amp way back when ;-) But heck, I was a noob, hacking together some
stuff for the project of the day.
Two quibbles: the inductor must be bypassed, else the added series
resistance can spoil its 'Q', and, more importantly, you'll get
undesired feedback around Q1, collector-to-base through the
current-sensing transistor Q2.
Secondly, Andrew's resistor in the collector of biasing/current
sensing transistor Q2 is a good idea, to avoid loading the base of RF
amplifier tranny Q1.
Cheers,
James Arthur
Winfield Hill wrote:
The circuit has three problems, all easily fixed. [...]
Here's a version that makes sure the inductor is bypassed at RF
frequencies, yet, per Win, avoids AM modulation of the bias from power
supply noise:
.. .---------------------+----------+------- +Vcc
.. | C1 | |
.. R1 100n _|_ Rs
.. 300mV --- 200mV
.. | R3 | R4 |
.. v\| .--/\/\--+--/\/\----+--------.
.. |---, | 50mV 50mV | |
.. /| | |/v | --- C2
.. +-----+----| C| --- 1n
.. | Q2 |\ C| L1 |
.. R2. | C| ===
.. 5mA .-. | GND
.. etc | | R5 |
.. | | | 1k +------------ out
.. GND '-' |
.. | Q1 |/
.. RF IN------+-----------------|
.. |\v
.. GND
Regards,
James Arthur
