W
W. eWatson
- Jan 1, 1970
- 0
I'm a bit further along with upgrading my observatory with electronics
with a control system to rotate the dome, and raise and lower the
shutter. I farmed out the PC board work to someone who has put relays,
soft start controls, and other devices in the two NEMA enclosures. It'll
probably take a month to get the boxes back. While waiting for that to
happen, I've decided to take a shot a the lower shutter.
As I probably mentioned here some time ago, there is a lower and upper
shutter. The lower shutter is about 33"x32", and has a glass window in
it. My guess it the upper shutter is 12'x3'. The shutters are on two
tracks, and roll along with wheels. Latches between the two can couple
them together, so they both move up and down together. If not latched,
the lower shutter sits on the apron (the circular structure on which the
dome sits) of the dome while the upper one moves up/down.
The lower shutter was a mistake, when I first built the obs. It is quite
unconventional. There may be 12 in the USA. As I quickly discovered,
taking images through the window resulted in slightly distorted images.
Not good. I had checked before buying the window shutter with five
people who owned such a shutter. (It has something of a reasonable
purpose for use in winter.) They all gave it thumbs up. I never asked
what imaging through the glass produced good images. Nevertheless, the
obs was still functional w/o the use of the window. The shutter weighs
about 120-90 pounds.
A typical lower shutter is like a drawbridge. That is it pivots on the
apron, and swings in or out with, in some cases, a hand winch, pulleys
and wires. It only needs to be positioned 10-15 degrees above the
horizon. Looking below that the sky is avoided because of the
atmospheric thickness. What I want is to take the current lower shutter
and make it look like a drawbridge. I plan to hire someone to do this.
However, my enclosure-box guy thinks I can operate with a linear motor.
He suggests using it on the apron and centered in the shutter. He's
short on details and working on another project now until he can get
back to mine. So my question is how is a linear motor going to help in
this situation. Why in the middle??? I haven't a clue.
