OH MY GOD, AMAZING DISCOVERY: Television signals travel through air from cable ?!?!?!
Skybuck Flying
While I was inspecting the cables I noticed some speakerset cables where
lieing on top of the WHITE television cable that carries the television
signal.
I decided to pull the white cable while the television was ON.
Then I moved the black soundspeaker cables under the white cable.
Then I re-plugged in the WHITE CABLE...
BUT JUST BEFORE I PLUGGED IN I NOTICED THE TELEVISION SIGNAL WAS RESTORED,
AT LEAST THE AUDIO SIGNAL ?!?!?!
I was like WHAT THE **** ?
I could have sworn it wasn't plugged in yet, or maybe just reaaally lighty.
So I decided to unplug it again and then simply hold the cable in the air ?!
Like 1 centimeter before the "hole".
AND IT FUCKING WORKS !
The television signal simply JUMPS ACROSS 1 CENTIMETER OF AIR !
Then I looked over the television and the television vision/visual was gray
like with weak visual signal... but the audio signal was crystal clear ?!
AMAZING !!!!
ALMOST LOOKS LIKE MAGIC ?!
HOLYSHIT.
Could this be the source of the interference ? Just pure speculation.. since
when the first booms occured... the television was off ?!
Bye,
Skybuck.
John Larkin
signal.
Television signals have been known to jump through MILES OF AIR!
UNBELIEVABLE!
John
Skybuck Flying
System just frooze again, this time speakerset was off.
I checked security log.
There is an entry for 22-8-2008.
This can't be it's still 14 september 2007.
I did not change the date to this date me thinks.
Here is a copy:
Event Type: Success Audit
Event Source: SECURITY
Event Category: System Event
Event ID: 513
Date: 22-4-2008
Time: 4:41:51
User: N/A
Computer: CP1098857-A
Description:
Windows is shutting down. All logon sessions will be terminated by this
shutdown.
For more information, see Help and Support Center at
http://go.microsoft.com/fwlink/events.asp.
Looks like a computer from @home network might have hacked my PC.
Or maybe it was randomly generated.
Very strange indeed.
I shall investigate this further tomorrow.
Bye,
Skybuck.
Skybuck Flying
It's a valid computer name for my ISP stuff.
Maybe I did change date sometime to test something who knows.
I am starting to believe it might be a denial of service attack.
Maybe somebody found a way to crash Windows XP Pro x64 editions.
Might even be a new worm... it has happened every few minutes which could
indicate a worm needing time to spread itself (searching) or simply a human
being wanting to crash it every few minutes.
Bye,
Skybuck.
Clifford Heath
You seem to be suffering under the illusion that anybody here gives a shit.
Just bugger off or shut up, will you?
Skybuck Flying
shit.
You seem to be under the impression you speak for all LOL.
Can you read other people's minds lol ?
TELEPATHETION LOL.
Bye,
Skybuck.
UNBELIEVABLE!
John- Hide quoted text -
- Show quoted text -
Not only that, but television signals have been known to jump FASTER
in the VACUUM of SPACE!
An IT friend of mine mentioned in passing that Headquarters is
planning on upgrading the fiber optic network.
"Upgrade it to what?" I asked.
He turned around to his co-worker. "To what?" He didn't know.
I told my friend, "Well, you know, light travels faster in a vacuum
than it does through glass. Maybe you can take a metal pipe from
here
to Headquarters, suck all the air out of it, and put a laser on either
end? You could DOUBLE your NETWORK SPEED!"
They didn't go for it, unfortunately.
Thanks for the laughs
John Larkin
here
Seriously, before fiber optics became practical, in the 1960's, Bell
Labs was experimenting with long-distance communications with light
running through pipes. The idea was to force thermal gradients in the
gas inside a pipe to provide a subtle refocussing effect that would
confine the light, sort of like a graded-index fiber.
Fiber optics got serious around 1970, when Corning pulled the first
fibers with usable attenuation levels.
Several people make free-space optical data links, usable between
buildings and such.
John
buildings and such.
Thanks a bunch!
Speed of light in air at STP is 99.97% of the speed of light in a
vacuum. Close enough...
http://en.wikipedia.org/wiki/Refractive_index
http://en.wikipedia.org/wiki/List_of_refractive_indices
Unfortunately, we'd need a huge tower to see headquarters (about 10
miles away). Any winds, and we'd get data transmission errors...
Skybuck Flying
Today it occured to me the new AN832-SLI motherboard might be showing the
same symptoms as the previous same kind of motherboard that died.
Today I kept my computer running without the internet connected and it ran
just fine.
I can remember that with the old motherboard it showed the same symptoms...
after plugging in the internet it would freeze.
I am not 100% sure the same symptons are now being displayed... but it's
starting to seem like it.
I have now connected the internet again to post this message.
Later I will disconnect it to work on some offline website and later today I
will go online again to see what happens.
Another explanation might be a denial of service attack.
So I will keep it short before PC freezes again.
Bye,
Skybuck !
just fine.
Bye,
Skybuck !
Boot it from a Knoppix Linux CD or DVD, and see if you still have the
same problems.
Skybuck Flying
Probably cause is identified.
Bad marvel miniport driver 8.27.
After removing this driver, which was probably installed by nvidia chipset
drivers after I installed the new motherboard, windows detected the ethernet
port and installed an old driver which was tested with UDP Speed Test 2 and
does seem to work ok !
So far so good !
Fingers crossed.
Meanwhile I have switched to nvidia's network controller, indicated as
ethernet port 8 the bottom port for internet access.
Just in case ! ;)
Bye,
Skybuck.
Skybuck Flying
same problems.
Good idea, I had the same idea, I had an old Knoppix 3.1 version, but it
doesn't have DHCP and doesn't work ?
I finally decided to test the network controllers with my UDP Speed Test 2
tool and I discovered the marvel miniport driver 8.27 was bad and crashed.
I have a minidump of it too.
So I switch to other ethernet port and so far so good ! ;)
Windows installed an old driver which I tested and seems working ok too.
Maybe I should burn a new knoppix version CD... but it must have DHCP...
Then again... I am kinda glad Knoppex CD was useless... because it forced to
me to think about alternatives and force me to discover and solve the
problem which I think I did for now :)
Bye,
Skybuck.
John Larkin
True, maybe we should start a fan club for him on Myspace, he could
get laid.
At least he might be able to take pictures of an ass that's not his
own.
And why do people like this keep typing LOL when they never say
anything funny?
John
Radiosrfun
own.
anything funny?
John
They're seeing the reflection of the "clown"/"dufus"/"ass" - in the
monitor - as they type..........
H
Herbert John \Jackie\ Gleason
same problems.
He is far too stupid to grasp what a knoppix diagnostic test is.
Look, dude. This idiot is now claiming his NEW MOBO is acting just
like his old MOBO.
I think the dope is causing ESD events on his gear, and is too damned
stupid to understand that HE is the root cause of ALL of his problems.
