OK, Here Is A LONG Shot, But....
EADGBE
.....Does anyone know where I can download the schematic for an Audio
Alchemy CD player?
The model is a Digital Drive System II (also known as a DDSII).
Many thanks in advance.....
Alchemy CD player?
You're right, long shot. Very long shot.
EADGBE
Why bother fixing it?
I got it for free; it seems like a (fairly) nice CD player; just
curious about the sound.
I really don't know if I actually need the schematic. I'm pretty sure
it's a bad op-amp. The CD spindle motor won't activate, even though
the motor tests fine and so do the transistors responsible for
supplying the motor voltage.
It's just something to tinker with on a rainy afternoon, that's
all......
Arfa Daily
all......
The fault you describe really is a bit "my car won't start even though
there's fuel in the tank. The engine cranks so the battery is fine. I
suspect it might be a bad radiator ... "
Sorry to put it that way, but very few problems with discs failing to spin
up, are ever anything to do with the motor's drive electronics, *unless* the
motor was faulty in the first place, in which case, occasionally, the motor
driver IC, where one is used, will be damaged. Where the drive is from a
four transistor bridge, it's very rare for them to have failed, bad motor or
not. The disc failing to spin up, when it's definitely *not* a motor
problem, is almost invariably because the system control is not releasing
the motor servo into a 'run' condition.
First checks should be :- If you move the laser down its track manually,
then open and close the drawer, does it then home ? Does the laser burn ?
Does it attempt focus ? With a disc in, does it achieve focus ? Does it
attempt to rotate the disc at all ? Are any pots in it way off centre (if
you don't know its pedigree, the phantom pot-twiddler may have been in there
before you ... ) d;~}
Collect a bit more info, then let us know, and we'll see if we can suggest
some more things you can look for.
Arfa
EADGBE
Arfa:
Thanks for the helpful information.
All I know at this stage is that the CD will not spin under any
condition...HOWEVER, when you turn the power off, the CD will spin
maybe a quarter of a turn while the unit is powering down.
And here's a strange fact: The other day I started messing with the
player after having it sit for a couple of weeks. I switched it on
and inserted a disc. Quite unexpectedly, it spun the disc and the
disc's track information appeared in the digital readout window!
At that point I should have pressed "play" to see what would happen,
but I ejected the disc and re-inserted it. Back to square one--the
disc didn't move.
This has been the one and only time the player has ever spun a disc
since I acquired it.
I have measured the voltage coming off of the four-transistor bridge.
Whenever a disc is inserted, the necessary 5 volts appears for a MICRO-
second, and then the voltage goes back to zero.
Sam Goldwasser
EADGBE said:
Arfa:
disc didn't move.
Respectfully, you emailed me first about this player. I assumed you
had actualy looked in the CD repair FAQ. Apparently, that wasn't the case.
Instead of taking up everyone's time answering basic questions, please
go to the "startup problems" sections there and attempt to determine
exactly what it is or is not doing. Then, everyone can be of more
help.
http://www.repairfaq.org/sam/cdfaq.htm#cdsup
As has been noted by others, the spindle motor failing to spin is almost
never a problem with the motor or its immediate driving electronics, but
rather with the optical pickup not getting focus lock due to any number
of causes. With your erratic behavior it could even be a something
mundane like a bad flex cable. And, it could still be a dirty lens.
--- sam | Sci.Electronics.Repair FAQ: http://www.repairfaq.org/
Repair | Main Table of Contents: http://www.repairfaq.org/REPAIR/
+Lasers | Sam's Laser FAQ: http://www.repairfaq.org/sam/lasersam.htm
| Mirror Sites: http://www.repairfaq.org/REPAIR/F_mirror.html
Important: Anything sent to the email address in the message header above is
ignored unless my full name AND either lasers or electronics is included in the
subject line. Or, you can contact me via the Feedback Form in the FAQs.
EADGBE
Hi, Sam:
I really apologize, but I don't think I e-mailed you about this
player. Unless I am having a severe case of amnesia, my original post
here is the first time I have discussed this player online. I did
have a question about a Yamaha player a couple of months ago, but that
issue has been resolved.
If I did indeed e-mail you about this player, please accept my
apologies. I will consult the CD repair FAQ as you have directed.
EADGBE said:
Hi, Sam:
My apologies. It was someone else. Probably the "long shot" part
made me think it was you. :)
Anyhow, do read the CD repair FAQ and then you can post your findings.
EADGBE
I have looked at the CD repair FAQ (very informative!), and I have
done the following:
1. I have cleaned the lens with isopropyl alcohol.
2. I have discovered that the laser pickup WILL NOT re-center itself
under any condition if I manually move it away from the motor spindle.
3. As far as I can tell by simple observation, the laser pickup DOES
NOT light up under any condition. (I looked at the lens from an
oblique angle about 6 inches away from it in a darkened room.)
4. I have verified that the lens drive motor AND the CD spindle motor
do work OK. (I unplugged each motor's wiring harness and applied a
small DC voltage.)
5. I have cleaned the contacts on the little leaf switch that opens
and closes whenever the CD drawer opens and closes and verified that
the switch is opening and closing normally.
6. I have verified that all wiring harness connectors are clean and
well-seated.
Somehow, this player simply will not turn the CD playing circuits on
when the drawer closes. I think the logic IC is fried. Oh well, I
needed a few electronic parts, so now I have a whole box full!
Thanks to everyone for your help....
done the following:
This may be the main problem. This is usually done regardless of the
state of the laser pickup. So, either the sensor isn't working or
there is a problem with the motor driver.
So, not even a tiny red dot?
Did you reset the sled to the center? It might not light up if the
sensor thinks it's starting at the wrong place.
Else, there is a problem with turning on the laser. You did say it
recognized the ToC once, right? So the laser itself works.
Could be a bad connection/bad cable.
small DC voltage.)
well-seated.
Doubt it. :) Certainly possible, but the most complex most expensive
part really isn't likely to be bad.
Arfa Daily
done the following:
small DC voltage.)
well-seated.
OK. Well your biggest clue there is that the laser never homes under any
circumstances. This means, probably 75% of the time at least, that the
problem is power supply related. I don't know if on that model, any psu
voltages are silk screened on the board by links, test points, or
connectors. If they are, look for the 5v that feeds the system control
logic, and the 8v (typically) that feeds the motor circuits. It's usually
called something like "+8M" or "M8v" or "Mot8v". If you can't find any
markings, look for 3 terminal monolithic regulator ICs - like 7805 and 7808
and 7909 and so on. On all types, positive and negative, "out" is the far
right pin with the heatsink away from you. On 78 positive types, "in" is the
left-most pin. On 79 negative types, it's the centre pin. Check for correct
output voltage, and that the voltage is 'clean'. Failure of the little
decoupling electros by the sides of them, can cause them to oscillate, which
wreaks havoc in the following circuitry.
If any have low output voltage, check them to see how hot they are getting.
If they are cold, and the input voltage is at least 15% above the expected
output voltage, suspect the regulator itself. With the 5v logic supply, it
is *particularly important* that it lies between 4.8 and 5.2v, and
preferably as close to 5v exactly, as possible. Also that it is very clean
(check with a 'scope).
If it doesn't have 78 / 79 series regulator chips, look for regulator
transistors, which may be either flatpak types, or those taller than normal
D-line types (like a big TO92 package). Look particularly, for any where the
pcb underneath looks scorched or discoloured.
As another bit of a test before you start digging in to component level, you
can try having a look at the voltages on either side of the 'tray closed'
switch, and just make sure that they do change when the tray *is* fully
closed. Also, you can push the laser all the way back home by hand, and just
see if the laser does then burn, and the focus seek operation starts. Should
be enough to get you going.
Arfa
EADGBE
Arfa:
You hit the nail on the head. The problem appears to be related to
the power supply...or at least to a component downstream from the
power supply.
Right next to the connector that leads to the laser assembly, one of
the contacts is labeled "5V". Measuring this contact gives me less
than half a volt under all circumstances.
This 5V contact leads directly to the collector of a 2SA1270
transistor. The transistor checks out OK, although the same half a
volt reading is measured at the collector. There is a jumper wire
that leads to the emitter of this same transistor. It is also clearly
labeled "5V", and it measures a healthy 5.08V.
The base of this transistor is connected, via a 10k resistor, to the
middle lead of a very small transistor with "C114" on the case. If it
is a 2SC114, I cannot readily find a replacement for this transistor,
and I cannot find a datasheet, either, so I don't know how to check
this transistor. It gives me weird readings whenever I test it in
standard NPN or PNP pin configurations. IT DOES NOT SEEM TO BE
DEFECTIVE, HOWEVER, because there are several "C114" transistors and
they all give me extremely similar readings whenever I attempt to
measure them in standard NPN and PNP pin configurations. There are
also a couple of 100uF/16V electrolytics in this circuit used as
couplings to ground, but they check out fine with my ESR meter and my
analog ohmmeter.
I am going to attempt to keep checking upstream to see where things
break down.
Arfa Daily
EADGBE said:
Arfa:
power supply.
analog ohmmeter.
break down.
Hmmm. I haven't specifically looked up this transistor, but I think you
would be correct in assuming that it is "2SC", in which case, it is NPN by
default. However, that said, if the readings are 'odd', and compare
similarly with others of the same number, then it's probably one of the
types which has internal resistors connected to some of the terminals -
these are very common. From the configuration that you are reporting, I
would suspect that this is in fact a switch circuit, probably driven by the
system control micro, so it may or may not be faulty. At an 'experienced
guess' I would think that you would be expecting to see some change in
voltage level at the 10 k resistor, and further back at the base leg of the
small transistor, as a result of shifting the unit from some quiescent state
to an active one i.e. from "standby" to "on" or from "stop" to "play". If
you do see such a level shift, but the 5v never appears at the output of the
2SA1270 (which will be PNP, incidentally) then you do have a problem in this
circuit. If you're brave, you can always link the collector of the 2SA to
its emitter, thus 'simulating' the switched on condition, and see what
happens. It will at least tell you if the primary problem is anything to do
with this voltage apparently being missing. If you're not quite brave enough
to do it by putting a screwdriver tip across the transistor leads, solder a
1 ohm fusible resistor across there.
Arfa
Mark D. Zacharias
the system control micro, so it may or may not be faulty. At an
'experienced guess' I would think that you would be expecting to see some
change in voltage level at the 10 k resistor, and further back at the base
leg of the small transistor, as a result of shifting the unit from some
quiescent state to an active one i.e. from "standby" to "on" or from
"stop" to "play". If you do see such a level shift, but the 5v never
appears at the output of the 2SA1270 (which will be PNP, incidentally)
then you do have a problem in this circuit. If you're brave, you can
always link the collector of the 2SA to its emitter, thus 'simulating' the
switched on condition, and see what happens. It will at least tell you if
the primary problem is anything to do with this voltage apparently being
missing. If you're not quite brave enough to do it by putting a
screwdriver tip across the transistor leads, solder a 1 ohm fusible
Arfa
The "114" is indeed a digital transistor, a DTC114.
Mark Z.
Arfa Daily
Mark Z.
Thanks Mark. There you go then. Mark confirms that it is a DTC114 digital
transistor, which means that it is a conventional bipolar type, but with
internal resistors. This all but confirms what I was thinking, and that it
is a switch stage for a 5v rail to somewhere, derived from a permanent 5v
rail, that you are looking at.
Arfa
EADGBE
Arfa:
Are you saying that I should suspect the DTC114 or the 2SA1270? Or
something else?
I'm betting on the DTC114 being the culprit.
Arfa Daily
EADGBE said:
Arfa:
something else?
Well, it may be the culprit, but you did say that it seemed to compare
favourably, with others of the same type. It should be easy to check if this
stage is working or not, with a couple of voltage measurements. Just check
at the base of the DTC114, to see if the voltage there ever changes when you
alter things i.e. open and close the drawer, hit the PLAY button, hit the
STOP button, go from standby to on etc. If the voltage does change, then
check at the collector or emitter, and see if there is a corresponding, or
inverse change there. If not, then the DTC may well be faulty. If there is
never any change at the base of the DTC, then this is likely not the stage
that's at fault, and it's probably just not being switched by the system
control micro, as a result of some other condition not having been
fulfilled. As I said previously, you can always 'force' the stage, and make
the 5v appear on that second link ...
Try to be logical with the fault location process. Try to understand how the
stage that you are troubleshooting works, and then formulate a set of tests
that will prove out the various sections of it. Only do one test at a time,
and analyse the result against what you were expecting. Use the result
gained to re-evaluate the next test you had planned, and see if it is still
valid, or could be altered to provide you with more information, based on
what you've just found out. Try to remember that fault finding is a dynamic
procedure, which produces 'branches' and deviations from a basic 'model'
that you work out for your tests, at the beginning.
Arfa
