One time PCB needed
  • Thread starter Dave, I can't do that
  • Start date
I am new to tis group but I have built a lot of kits over the years so
I am not all that new to soldering.
I have a small project with a 555 and about 10 other parts. It is a
very basic 5v, 5KHz PWM circuit. I have downloaded Eagle Lite but the
learning curve is too steep for something I probably will never use
again.
Is there anyone here who could make some changes to a schematic and
then layout a board for Toner transfer and etching. I have an
extensive hobby metalworking machine shop at home and can offer
machining for a prototype in return.
I have the original schematic and the list of changes needed.
Thanks in advance.
again.
Thanks in advance.
Go over to sci.electronics.design there is a thread going on about
'Affordable PCB Layout Software' there is also a Yahoo group devoted
to PCB making.
regards,
al
Phil Allison
"Dave, I can't do that"
again.
** Have you never heard of Veroboard ??
http://en.wikipedia.org/wiki/Stripboard
Take me about 15 minutes to have that circuit up and working.
...... Phil
Jasen Betts
again.
if you only want one, and only have about 30 endpoints why not
use a permanent marker on the board and then etch, or as Phil
suggests, just use stripboard.
Bye.
Jasen
Rich Webb
There's also a free (as in beer, not FOSS) stripboard layout editor
available at http://www.veecad.com. While it may seem a little silly do
a layout on a PC for a small, one-off project it is awfully nice to be
able to decide that *this* works better over *there* before you've
started soldering. The user interface is easy to work with so don't
expect a terribly tall learning curve.
While it is possible to use Veecad without a netlist, it is able to read
several common styles. See http://www.veecad.com/editors.html
If you already have a paper schematic then generating a new one in a
schematic capture app to build a netlist shouldn't take long. Kicad
(free as in FOSS) can produce netlists in a format that Veecad can use.
http://www.lis.inpg.fr/realise_au_lis/kicad/
Stripboard can be a bit hard to find sometimes. One on-line source that
I've used that has them for reasonable prices is
http://www.futurlec.com/ProtoBoards.shtml
Thanks to everyone who replied. I will check out the suggestions.
I know I could use strip board but I don't like it especially when I
stand to blow up a $3600 laser if I get it wrong, but the idea of
laying it out first in software for strip board sounds like a useful
approach.
The idea of automatically laying out the board from a schematic
appealed as it removed a whole shit load of potential for error.
neon
Oct 21, 2006
1,325
EXPRESSPCB easy to use even a fool can use it. forget about eagle good but the learng curve is silly as opposed to expresspcb. both free.
You are going to check the output waveforms before hooking up the
laser either way, right?
Oh you betcha David, I will actually attempt to have it destroy itself
before it gets near the laser. In fact I have ordered 5 sets of parts,
just in case.
I have a TEK TDS210 gathering dust in the garage.
