Opam question
N
Nick
Hi guys,
Why is RL resistor at the output of an OPAM in an electronics design??
Thanks and regards,
Nick
K
kell
Nick said:
Hi guys,
Thanks and regards,
Nick
So it doesn't short out? Op amps have low output impedance.
Eeyore
RL is short for *load resistor*. Loads ( if required ) do indeed normally
connect at the output !
They are rarely necessary though. You should post a schematic.
A clueless answer from a Google groups user to a clueless question from another
Google groups user !
No surprise there I guess ?
Graham
Andrew Holme
Nick said:
Hi guys,
Thanks and regards,
Nick
In series with the output or to ground?
A series resistor might be inserted to reduce output current.
A 1K resistor to ground on the output of an LM324 op-amp reduces crossover
distortion, by biasing the output stage into class A.
N
Nick
With respect to the ground, yes RL stands for Load resistor. How can a
load resistor help in not shorting the OPAM, here a series resistor can
do!!
In the fashion below:
-----|/ _|_
|RL|
GND
Thanks and regards,
Nick
Peter Bennett
do!!
-----|/ _|_
|RL|
Very often, sample circuits will show an "Rl" like that, just to show
how the load should be connected. In Real Life, you would rarely put
a resistor there - you connect your load, whatever it may be, in place
of Rl.
