Operating a parallel in / serial out shift register
Hi all,
I'm trying to get a 74hc165 to work.(datasheet:
http://www.farnell.com/datasheets/72353.pdf).
I'm operating it as follows, but I'm not sure if its correct because
when I make one input high, I read the serial out like all inputs were
high:
<code>
// Shift bits to register
LOAD = low
LOAD = high
for (i = 0; i < 8; i++)
CLOCK = low
CLOCK = high
// Read DATA
if (DATA == 1)
set bit num i.
</code>
Does anyone know why this is giving me all '1' when only one input is
high?
Greetings Roxlu
Deefoo
Hi all,
high:
<code>
LOAD = low
LOAD = high
CLOCK = low
CLOCK = high
// Read DATA
if (DATA == 1)
set bit num i.
</code>
high?
Greetings Roxlu
What did you do with the clock inhibit pin?
--DF
--DF
I put it to gnd...I've added some resistors (10K) to A/H to gnd. Most
of the data I read from the serial out is correct now.. 95%, though I
want 100%.. Any suggestions?
Greetings
Deefoo
Greetings
Just one shift register with clk, load & out connected to a microcontroller?
Are the resistors from A-H to gnd supposed to be pull-down resistors because
there are also switches to +5V?
Ultra-simple program running that just reads the shift register or is it
doing other things as well?
--DF
--DF
Yes, it's just only that ulta-simple program. Though I'm also sending
the result using rs-232/usart.
gr.
Deefoo
gr.
You should analyse the errors you see. Do they occur randomly or only after
flipping a switch (contact bouncing). Is the result shifted too much or not
enough (noise/timing). You may have noise problems and your clock or load
may not get through all the time. Or too much clocks. Put a bypass cap on
the shift register. Does it work better if you make the clock & load strobes
longer? Could it be possible that you are reading faster than that you are
sending? Overwriting part of the output buffer?
--DF
--DF
Thanks for the suggestions, I'm gonna try and I'll be back later.
gr.
