Optimal distance and angle of modules on flat roof
Armin Lampert
Is there any knowledge of optimal distance and angle of modules on flat roof
regarding the annular output?
Thanks for any tips,
Armin
Glenn jacobs
Armin
It depends on a lot of things. I am not sure what you mean by distance,
but if you are in an area that gets snow they should be located where it is
possible to clean the snow from the panels. Generally they should point
due South and if they are to be fixed, that is not adjustable, generally
their angle to the horizontal should be equal to the latitude of your
location. If they are to be fixed, but with a vertical adjustment for
seasonal changes, I make mine plus or minus 20 degrees.
Having said that, the local topology has to be taken into account. That is
there anything that will block the Sun during the day? Also is there a
particular season that you want to maximize the output? If so you might
want to adjust the angle to the horizontal of the panels, if they are to be
without a seasonal adjustment.
JakeInHartsel
Armin Lampert
I think about the shadowing of modules by itself. My intention is to get a
large package of CIS modules on a certain roof area by a flat module angle
of about 10°.
Armin
Blue Cat
of about 10°.
As long as you have urestricted access to the sun during most of the day,
the mounting angle should coincide with the position of the sun at noon
during equinox. If you can change the mounting angle during the year, so
much the better.
Armin Lampert
My position is Munich with 48,25°. In the morning and afternoon the modules
will be shadowed when the distance between the modules is small (for example
40 cm).
Armin Lampert
Of course, I don't like to give my money to a warehouse. On the other hand,
I don't have 50 m distance between the rows of modules. But what is the
reasonable distance between them? With 0° the distance would be 0.
Armin
