Oscilloscope and AC generator questions/observations
Eric R Snow
Greetings All,
I am learning how to use an oscilloscope. The one I have is a TEK
465B. It sure is amazing what this device can measure. I have some
questions that I haven't been able to find answers for yet. I decided
to measure the frequency of a small (850 watt) AC generator. It's
useful for powering lights, drill motors and the like. To make sure I
understood what the display should look like the first thing measured
was the 60Hz from the power company. Using a step down xmfr with a 9
volt secondary the 'scope displayed slightly over 8 divisions with the
divisions set at 2 mS. That works out to just over 16 mS which is 60
Hz. So I knew that the scope was showing what I wanted. The wave form
wasn't perfect though. On the rising side of the wave the form was
distorted slightly instead of being a perfect sine wave. It looked
sort of like a little part of the curve was a straight line. Could
this be caused by the step down Xmfr? When measuring the wave form
from the generator it appeared to be outputting 45Hz frequency. The
wave was 11.5 divisions long. The 'scope settings were the same as
when measuring the line power. Also the wave wasn't a smooth sine
wave. It looks like the wave is made from a rippled string. Are these
harmonics? What determines the frequency of an AC generator? The label
on the generator says it has a 60 Hz output. The 2 stroke engine
driving it seems to be operating at the proper RPM just by listening
to it but it may be running too slow. I will use an optical tachometer
to measure the actual RPM. Another test that is going to be done is to
power a small induction motor and measure it's rpm. This motor is a
1/8 HP 1725 RPM motor. If the 45 HZ measurement is accurate then the
motor should spin about 1300 RPM (I think). I have used this generator
with this motor in the past to power a pig roasting spit and the motor
worked fine and ran cool so I know the starting windings were not
energized while it was being powered by this generator. But it's
geared down to spin the spit at about 1 RPM so if it spun slower it
would be hard to tell.
Thanks for reading and any answers.
Cheers,
Eric R Snow
James Douglas
Eric said:
Greetings All,
Cheers,
Eric R Snow
Google for "how to use an oscilloscope" and you can get a ton of
information in regards to questions like this, I downloaded and printed
a great PDF from HP I believe which talked about scope basics and
various things, I did just last month and found that signals don't
always appear on the scope as they do in books, etc.
What I did is google how to use a 555 timer to create a little circuit
in which I could test the scope, meter etc, it took about 30 minutes and
I was satisfied that the frequency was correct on the scope and meter.
I still think my scope should be calibrated but have not found anyone
local to do it
Dan Hollands
Eric R Snow said:
Greetings All,
Cheers,
Eric R Snow
You should be able to look directly at the 120Vac line voltage with the
scope. You can also usually just grab onto the end of the scope probe and
get enough 60Hz pickup to verify the approximate sweep freq.
From your description it is almost certain the the motor powered generator
is running slow. The power company waveform will be very close to 60Hz
Dan
Dan Hollands
1120 S Creek Dr
Webster NY 14580
585-872-2606
[email protected]
www.QuickScoreRace.com
U
unbiased
Scoping the alternator under no load conditions will look different
that half or full load.
Greetings All,
-snip-
