Oscilloscope repair Tektronix 2246 Chicago
Hello everyone my Tektronix 2246 oscilloscope just went out on me
tonight. First it started making frequencies noises randomly, then it
took multiple tries to get it started. Now it just makes chirp and
doesn't start all together. I opened it up at looked at the power
supply and it looks fine, no obvious damage. Is there a common problem
i could fix on my own? Can someone recommend a good repair shop in the
Chicago land area.
Rich
carneyke
Chicago land area.
Rich
Could be bad capacitors in the power supply, they can cause audible
noise.
Andreas Tekman
Chicago land area.
Rich
Bad/dry caps in the Tektronix pwr supply of this 22xx scope are a
common failure, results are as you described.
If you can chk and change the caps, it should be worth the effort.
gd luck.
hth,
Andreas
Jim Yanik
gd luck.
hth,
Andreas
Don't forget to use *low-ESR* switcher-grade caps.Since the 2246 PS uses
odd value caps,the next closest standard value over the uf and voltage
ratings will suffice.
Also,the 2246 PS is underneath the top board;that has to be lifted to
access the PS board,but the PS unplugs.
