Overhead Projector
My overhead projector light is dim or I can't see the letters and
pictures clearly, is it something to do with the light or do I need
service?
Zee
Thank You
TimPerry
service?
Zee
Thank You
LCD projector or RGB?
jakdedert
I believe the header says 'overhead'; in which case the OP needs a new bulb.
jak
TimPerry
jak
ah.. i was thinkin of a ceiling mounted video projector.
check to see if you have a 220V lamp running on a 110V outlet
Stan
[email protected] wrote:
}My overhead projector light is dim or I can't see the letters and
}pictures clearly, is it something to do with the light or do I need
}service?
Open the top and see if the bulb's glass is crystal clear or grey-ish;
if it's not clear, replace it. DO NOT touch the bulb with your bare
fingers. Clean the lens and the glass plate. Make sure the bulb's
voltage rating is the same as the power outlet you're plugged into.
Stan.
