Danny Daviss
- Mar 16, 2013
- 67
- Joined
- Mar 16, 2013
- Messages
- 67
Why does over-loading an output cause transistors to blow or have excessive current to flow through them?
Can over-loading raise the DC supply voltage? why does over-loading raise the DC supply voltage?
Overload i mean a load on the output of the circuit, why does overload cause excessive current to flow through the transistors? Example if u plug to many things in your ac outlet it will overload the circuit or ac outlet causing it to catch on fire. I guess the load draws to much current but why would the transistors have excessive current flow or heat up?
why do components overheat and blow if the output is overloaded? the overloading is drawing to much current but why would the components before the output overheat and blow?
