PALASM Proficiency anybody??
  • Thread starter Frank-Stefan Müller
  • Start date
F
Frank-Stefan Müller
Hi there,
i?m working on a state machine design with PALASM, but it doesn?t work
as intended. Its an excitation circuit for a 5-phase stepper motor
driver. Compilation runs without errors or warnings, but simulation
shows strange flaws.
Any body able and willing to help me?
Frank
Rich Webb
Is there any reason not to put the code up here?
I don't trust simulations. For me, they seem to be the source of the
funny results more often than mistakes I've made. If it is a smallish
project you should be able to check your work by hand. Double check
the inverted vs non-inverted because that seems to be the easiest
mistake to make.
It might also be worth looking at WinCUPL as an alternative to PALASM.
It has been a while since I've done any GAL work but I don't recall too
much pain with WinCUPL. If the dialects are as similar as the Atmel link
below implies, it may be worth a look just to see how the design behaves
in a different environment.
http://www.atmel.com/dyn/products/faq_card.asp?faq_id=1347
petrus bitbyter
Frank-Stefan Müller said:
Hi there,
i?m working on a state machine design with PALASM, but it doesn?t work as
intended. Its an excitation circuit for a 5-phase stepper motor driver.
Compilation runs without errors or warnings, but simulation shows strange
flaws.
Frank
Did a lot using Palasm at the time and still have a running version 1.5. If
you send the source allong with a descryption about what the circuit is
supposed to do, I'll have a look at it.
petrus bitbyter
F
Frank-Stefan Müller
Richard said:
Are all outputs synchrous?
yes, they are,here´s the source code:
;PALASM Design Description
;---------------------------------- Declaration Segment ------------
TITLE schritt5
PATTERN
REVISION 1
AUTHOR fsm
COMPANY mrt
DATE 12/10/09
CHIP schritt5 PAL22V10
;---------------------------------- PIN Declarations ---------------
PIN 1 CLOCK COMBINATORIAL ; INPUT
PIN 2 LI_RE COMBINATORIAL ; INPUT
PIN 3 ENA COMBINATORIAL ; INPUT
PIN 4 RES COMBINATORIAL ; INPUT
PIN 12 GND ; INPUT
PIN 13 OE COMBINATORIAL ; INPUT
PIN 14 WP1 REGISTERED ; OUTPUT
PIN 15 WN1 REGISTERED ; OUTPUT
PIN 16 WP2 REGISTERED ; OUTPUT
PIN 17 WN2 REGISTERED ; OUTPUT
PIN 18 WP3 REGISTERED ; OUTPUT
PIN 19 WN3 REGISTERED ; OUTPUT
PIN 20 WP4 REGISTERED ; OUTPUT
PIN 21 WN4 REGISTERED ; OUTPUT
PIN 22 WP5 REGISTERED ; OUTPUT
PIN 23 WN5 REGISTERED ; OUTPUT
PIN 24 VCC ; INPUT
;----------------------------------- STATE SEGMENT ------
STATE
MOORE_MACHINE
START_UP := POWER_UP -> S0
;------STATE ASSIGNMENT EQUATIONS --------------------------------
S0 = WP1 * /WN1 * /WP2 * WN2 * WP3 * /WN3 * /WP4 * WN4 * /WP5
* /WN5
S1 = WP1 * /WN1 * /WP2 * WN2 * WP3 * /WN3 * /WP4 * WN4 * WP5
* /WN5
S2 = /WP1 * /WN1 * /WP2 * WN2 * WP3 * /WN3 * /WP4 * WN4 * WP5
* /WN5
S3 = /WP1 * WN1 * /WP2 * WN2 * WP3 * /WN3 * /WP4 * WN4 * WP5
* /WN5
S4 = /WP1 * WN1 * /WP2 * /WN2 * WP3 * /WN3 * /WP4 * WN4 * WP5
* /WN5
S5 = /WP1 * WN1 * WP2 * /WN2 * WP3 * /WN3 * /WP4 * WN4 * WP5
* /WN5
S6 = /WP1 * WN1 * WP2 * /WN2 * /WP3 * /WN3 * /WP4 * WN4 * WP5
* /WN5
S7 = /WP1 * WN1 * WP2 * /WN2 * /WP3 * WN3 * /WP4 * WN4 * WP5
* /WN5
S8 = /WP1 * WN1 * WP2 * /WN2 * /WP3 * WN3 * /WP4 * /WN4 * WP5
* /WN5
S9 = /WP1 * WN1 * WP2 * /WN2 * /WP3 * WN3 * WP4 * /WN4 * WP5
* /WN5
S10 = /WP1 * WN1 * WP2 * /WN2 * /WP3 * WN3 * WP4 * /WN4 * /WP5
* /WN5
S11 = /WP1 * WN1 * WP2 * /WN2 * /WP3 * WN3 * WP4 * /WN4 * /WP5
* WN5
S12 = /WP1 * /WN1 * WP2 * /WN2 * /WP3 * WN3 * WP4 * /WN4 * /WP5
* WN5
S13 = WP1 * /WN1 * WP2 * /WN2 * /WP3 * WN3 * WP4 * /WN4 * /WP5
* WN5
S14 = WP1 * /WN1 * /WP2 * /WN2 * /WP3 * WN3 * WP4 * /WN4 * /WP5
* WN5
S15 = WP1 * /WN1 * /WP2 * WN2 * /WP3 * WN3 * WP4 * /WN4 * /WP5
* WN5
S16 = WP1 * /WN1 * /WP2 * WN2 * /WP3 * /WN3 * WP4 * /WN4 * /WP5
* WN5
S17 = WP1 * /WN1 * /WP2 * WN2 * WP3 * /WN3 * WP4 * /WN4 * /WP5
* WN5
S18 = WP1 * /WN1 * /WP2 * WN2 * WP3 * /WN3 * /WP4 * /WN4 * /WP5
* WN5
S19 = WP1 * /WN1 * /WP2 * WN2 * WP3 * /WN3 * /WP4 * WN4 * /WP5
* WN5
;TRANSITION EQUATIONS
S0 := LINKS -> S19
+ RECHTS -> S1
+-> S0
S1 := LINKS -> S0
+ RECHTS -> S2
+-> S1
S2 := LINKS -> S1
+ RECHTS -> S3
+-> S2
S3 := LINKS -> S2
+ RECHTS -> S4
+-> S3
S4 := LINKS -> S3
+ RECHTS -> S5
+-> S4
S5 := LINKS -> S4
+ RECHTS -> S6
+-> S5
S6 := LINKS -> S5
+ RECHTS -> S7
+-> S6
S7 := LINKS -> S6
+ RECHTS -> S8
+-> S7
S8 := LINKS -> S7
+ RECHTS -> S9
+-> S8
S9 := LINKS -> S8
+ RECHTS -> S10
+-> S9
S10:= LINKS -> S9
+ RECHTS -> S11
+-> S10
S11:= LINKS -> S10
+ RECHTS -> S12
+-> S11
S12:= LINKS -> S11
+ RECHTS -> S13
+-> S12
S13:= LINKS -> S12
+ RECHTS -> S14
+-> S13
S14:= LINKS -> S13
+ RECHTS -> S15
+-> S14
S15:= LINKS -> S14
+ RECHTS -> S16
+-> S15
S16:= LINKS -> S15
+ RECHTS -> S17
+-> S16
S17:= LINKS -> S16
+ RECHTS -> S18
+-> S17
S18:= LINKS -> S17
+ RECHTS -> S19
+-> S18
S19:= LINKS -> S18
+ RECHTS -> S0
+-> S19
;OUTPUT EQUATIONS
;WP1.TRST = OE
;WN1.TRST = OE
;WP2.TRST = OE
;WN2.TRST = OE
;WP3.TRST = OE
;WN3.TRST = OE
;WP4.TRST = OE
;WN4.TRST = OE
;WP5.TRST = OE
;WN5.TRST = OE
;CONDITION EQUATIONS
CONDITIONS
LINKS = LI_RE * ENA
RECHTS = /LI_RE * ENA
SIMULATION
TRACE_ON ENA CLOCK LI_RE WP1 WN1 WP2 WN2 WP3 WN3 WP4 WN4 WP5 WN5
SETF /OE /CLOCK ENA
;SETF WP1 /WN1 /WP2 WN2 WP3 /WN3 /WP4 WN4 /WP5 /WN5
;SETF /OE CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
F
Frank-Stefan Müller
mistake to make.
thanx for your help!
TITLE schritt5
PATTERN
REVISION 1
AUTHOR fsm
COMPANY mrt
DATE 12/10/09
PIN 12 GND ; INPUT
PIN 24 VCC ; INPUT
STATE
MOORE_MACHINE
* /WN5
* /WN5
* /WN5
* /WN5
* /WN5
* /WN5
* /WN5
* /WN5
* /WN5
* /WN5
* /WN5
* WN5
* WN5
* WN5
* WN5
* WN5
* WN5
* WN5
* WN5
* WN5
S0 := LINKS -> S19
+ RECHTS -> S1
+-> S0
S1 := LINKS -> S0
+ RECHTS -> S2
+-> S1
S2 := LINKS -> S1
+ RECHTS -> S3
+-> S2
S3 := LINKS -> S2
+ RECHTS -> S4
+-> S3
S4 := LINKS -> S3
+ RECHTS -> S5
+-> S4
S5 := LINKS -> S4
+ RECHTS -> S6
+-> S5
S6 := LINKS -> S5
+ RECHTS -> S7
+-> S6
S7 := LINKS -> S6
+ RECHTS -> S8
+-> S7
S8 := LINKS -> S7
+ RECHTS -> S9
+-> S8
S9 := LINKS -> S8
+ RECHTS -> S10
+-> S9
S10:= LINKS -> S9
+ RECHTS -> S11
+-> S10
S11:= LINKS -> S10
+ RECHTS -> S12
+-> S11
S12:= LINKS -> S11
+ RECHTS -> S13
+-> S12
S13:= LINKS -> S12
+ RECHTS -> S14
+-> S13
S14:= LINKS -> S13
+ RECHTS -> S15
+-> S14
S15:= LINKS -> S14
+ RECHTS -> S16
+-> S15
S16:= LINKS -> S15
+ RECHTS -> S17
+-> S16
S17:= LINKS -> S16
+ RECHTS -> S18
+-> S17
S18:= LINKS -> S17
+ RECHTS -> S19
+-> S18
S19:= LINKS -> S18
+ RECHTS -> S0
+-> S19
;OUTPUT EQUATIONS
;WP1.TRST = OE
;WN1.TRST = OE
;WP2.TRST = OE
;WN2.TRST = OE
;WP3.TRST = OE
;WN3.TRST = OE
;WP4.TRST = OE
;WN4.TRST = OE
;WP5.TRST = OE
;WN5.TRST = OE
CONDITIONS
LINKS = LI_RE * ENA
SIMULATION
SETF /OE /CLOCK ENA
;SETF /OE CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
petrus bitbyter
TITLE schritt5
PATTERN
REVISION 1
AUTHOR fsm
COMPANY mrt
DATE 12/10/09
INPUT
INPUT
INPUT
INPUT
PIN 12 GND ;
INPUT
INPUT
PIN 24 VCC ; INPUT
STATE
MOORE_MACHINE
S0 = WP1 * /WN1 * /WP2 * WN2 * WP3 * /WN3 * /WP4 * WN4 * /WP5 *
/WN5
S1 = WP1 * /WN1 * /WP2 * WN2 * WP3 * /WN3 * /WP4 * WN4 * WP5 *
/WN5
S2 = /WP1 * /WN1 * /WP2 * WN2 * WP3 * /WN3 * /WP4 * WN4 * WP5 *
/WN5
S3 = /WP1 * WN1 * /WP2 * WN2 * WP3 * /WN3 * /WP4 * WN4 * WP5 *
/WN5
S4 = /WP1 * WN1 * /WP2 * /WN2 * WP3 * /WN3 * /WP4 * WN4 * WP5 *
/WN5
S5 = /WP1 * WN1 * WP2 * /WN2 * WP3 * /WN3 * /WP4 * WN4 * WP5 *
/WN5
S6 = /WP1 * WN1 * WP2 * /WN2 * /WP3 * /WN3 * /WP4 * WN4 * WP5 *
/WN5
S7 = /WP1 * WN1 * WP2 * /WN2 * /WP3 * WN3 * /WP4 * WN4 * WP5 *
/WN5
S8 = /WP1 * WN1 * WP2 * /WN2 * /WP3 * WN3 * /WP4 * /WN4 * WP5 *
/WN5
S9 = /WP1 * WN1 * WP2 * /WN2 * /WP3 * WN3 * WP4 * /WN4 * WP5 *
/WN5
S10 = /WP1 * WN1 * WP2 * /WN2 * /WP3 * WN3 * WP4 * /WN4 * /WP5 *
/WN5
S11 = /WP1 * WN1 * WP2 * /WN2 * /WP3 * WN3 * WP4 * /WN4 * /WP5 *
WN5
S12 = /WP1 * /WN1 * WP2 * /WN2 * /WP3 * WN3 * WP4 * /WN4 * /WP5 *
WN5
S13 = WP1 * /WN1 * WP2 * /WN2 * /WP3 * WN3 * WP4 * /WN4 * /WP5 *
WN5
S14 = WP1 * /WN1 * /WP2 * /WN2 * /WP3 * WN3 * WP4 * /WN4 * /WP5 *
WN5
S15 = WP1 * /WN1 * /WP2 * WN2 * /WP3 * WN3 * WP4 * /WN4 * /WP5 *
WN5
S16 = WP1 * /WN1 * /WP2 * WN2 * /WP3 * /WN3 * WP4 * /WN4 * /WP5 *
WN5
S17 = WP1 * /WN1 * /WP2 * WN2 * WP3 * /WN3 * WP4 * /WN4 * /WP5 *
WN5
S18 = WP1 * /WN1 * /WP2 * WN2 * WP3 * /WN3 * /WP4 * /WN4 * /WP5 *
WN5
S19 = WP1 * /WN1 * /WP2 * WN2 * WP3 * /WN3 * /WP4 * WN4 * /WP5 *
WN5
;TRANSITION
EQUATIONS ---------------------------------------------------------
S0 := LINKS -> S19
+ RECHTS -> S1
+-> S0
S1 := LINKS -> S0
+ RECHTS -> S2
+-> S1
S2 := LINKS -> S1
+ RECHTS -> S3
+-> S2
S3 := LINKS -> S2
+ RECHTS -> S4
+-> S3
S4 := LINKS -> S3
+ RECHTS -> S5
+-> S4
S5 := LINKS -> S4
+ RECHTS -> S6
+-> S5
S6 := LINKS -> S5
+ RECHTS -> S7
+-> S6
S7 := LINKS -> S6
+ RECHTS -> S8
+-> S7
S8 := LINKS -> S7
+ RECHTS -> S9
+-> S8
S9 := LINKS -> S8
+ RECHTS -> S10
+-> S9
S10:= LINKS -> S9
+ RECHTS -> S11
+-> S10
S11:= LINKS -> S10
+ RECHTS -> S12
+-> S11
S12:= LINKS -> S11
+ RECHTS -> S13
+-> S12
S13:= LINKS -> S12
+ RECHTS -> S14
+-> S13
S14:= LINKS -> S13
+ RECHTS -> S15
+-> S14
S15:= LINKS -> S14
+ RECHTS -> S16
+-> S15
S16:= LINKS -> S15
+ RECHTS -> S17
+-> S16
S17:= LINKS -> S16
+ RECHTS -> S18
+-> S17
S18:= LINKS -> S17
+ RECHTS -> S19
+-> S18
S19:= LINKS -> S18
+ RECHTS -> S0
+-> S19
;OUTPUT EQUATIONS
;WP1.TRST = OE
;WN1.TRST = OE
;WP2.TRST = OE
;WN2.TRST = OE
;WP3.TRST = OE
;WN3.TRST = OE
;WP4.TRST = OE
;WN4.TRST = OE
;WP5.TRST = OE
;WN5.TRST = OE
CONDITIONS
LINKS = LI_RE * ENA
SIMULATION
SETF /OE /CLOCK ENA
;SETF /OE CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
Did a simple short run but as far as I see the simulation does what it is
expect toe do. So what's wrong with it?
PALASM4 PLDSIM - MARKET RELEASE 1.5 (7-10-92)
(C) - COPYRIGHT ADVANCED MICRO DEVICES INC., 1992
PALASM SIMULATION SELECTIVE TRACE LISTING
Title : schritt5 Author : fsm
Pattern : Company : mrt
Revision : 1 Date : 12/10/09
PAL22V10
Page : 1
gc c c c c c c c c c c c c c c c c c c c
ENA HHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHH
CLOCK LHHLHHLHHLHHLHHLHHLHHLHHLHHLHHLHHLHHLHHLHHLHHLHHLHHLHHLHHLHH
LI_RE LLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLL
WP1 LLHHHLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLHHHHHHHHHHHHHHHHHHHHHL
WN1 LLLLLLLLHHHHHHHHHHHHHHHHHHHHHHHHHHHLLLLLLLLLLLLLLLLLLLLLLLLL
WP2 LLLLLLLLLLLLLLHHHHHHHHHHHHHHHHHHHHHHHHHHHLLLLLLLLLLLLLLLLLLL
WN2 LLHHHHHHHHHLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLHHHHHHHHHHHHHHHL
WP3 LLHHHHHHHHHHHHHHHLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLHHHHHHHHHL
WN3 LLLLLLLLLLLLLLLLLLLLHHHHHHHHHHHHHHHHHHHHHHHHHHHLLLLLLLLLLLLL
WP4 LLLLLLLLLLLLLLLLLLLLLLLLLLHHHHHHHHHHHHHHHHHHHHHHHHHHHLLLLLLL
WN4 LLHHHHHHHHHHHHHHHHHHHHHLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLHHHL
WP5 LLHHHHHHHHHHHHHHHHHHHHHHHHHHHLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLL
WN5 LLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLHHHHHHHHHHHHHHHHHHHHHHHHHHHL
PAL22V10
Page : 2
petrus bitbyter
F
Frank-Stefan Müller
MooseFET said:
I looked but couldn't see anything too obvious unless it has to do
witht he fact that you didn't latch the direction controls. This
could make it mess up on a direction change. This could be an
external latch or just part of the design.
Have you tried burning a 22V10 and putting a scope on it?
yes, the display was exactly resembling the simulation result
I assume that WP# and WN# are driving transistors that work the
stepper coils. You are using a 9/20 duty cycle on all the coil
drives. On each clock, the phase should go 18 degrees.
I haven't looked at the 22V10's datasheet in a while. What is the
lowest number of AND gates in the macrocell? Could it be that your
compiler has actually not made the correct result without warning you?
I suppose this is true, but why? Could the LOWEST number of AND cells be
a concern? I disassembled the Jedec file, of course there are lots of
fuses blown, shold mean NOT blown, intact, but it seems to me, that not
all AND strings are used, so there should´t be a problem with missing terms.
petrus bitbyter
<snip>
<snip>
Well, the impossible never happens but I never saw my last PALASM version
fail like this.
petrus bitbyter
petrus bitbyter
"MooseFET" <[email protected]> schreef in bericht
terms.
| IIRC the 22V10 has the option of inverting the outputs. I was
| thinking that PALASM may have made OR operations from that.
| You also have at least a few ORs in the state change coding.
| One flip flop will be set if:
| 1) It is set and it should remain so
| OR
| 2) You are running forwards and it should become set
| OR
| 3) You are running backwards and it should become set
| #1 is likely to explode into a long list of should remain so cases
| because each case where it is to remain set will be coded using one
| AND.
The 22V10 outputs can individually be programmed to be active high or active
low. Older PALs and older versions of PALASM tend to give some problems,
especially when PALs with fixed active low outputs were used.
In order to protect yourself against the confusion, always use the pinlist
to define an I/O-pin to be active high or active low. Then, in the
equations, use only positive logic.
petrus bitbyter
petrus bitbyter
TITLE schritt5
PATTERN
REVISION 1
AUTHOR fsm
COMPANY mrt
DATE 12/10/09
INPUT
INPUT
INPUT
INPUT
PIN 12 GND ;
INPUT
INPUT
PIN 24 VCC ; INPUT
STATE
MOORE_MACHINE
/WN5
/WN5
/WN5
/WN5
/WN5
/WN5
/WN5
/WN5
/WN5
/WN5
/WN5
WN5
WN5
WN5
WN5
WN5
WN5
WN5
WN5
WN5
;TRANSITION
S0 := LINKS -> S19
+ RECHTS -> S1
+-> S0
S1 := LINKS -> S0
+ RECHTS -> S2
+-> S1
S2 := LINKS -> S1
+ RECHTS -> S3
+-> S2
S3 := LINKS -> S2
+ RECHTS -> S4
+-> S3
S4 := LINKS -> S3
+ RECHTS -> S5
+-> S4
S5 := LINKS -> S4
+ RECHTS -> S6
+-> S5
S6 := LINKS -> S5
+ RECHTS -> S7
+-> S6
S7 := LINKS -> S6
+ RECHTS -> S8
+-> S7
S8 := LINKS -> S7
+ RECHTS -> S9
+-> S8
S9 := LINKS -> S8
+ RECHTS -> S10
+-> S9
S10:= LINKS -> S9
+ RECHTS -> S11
+-> S10
S11:= LINKS -> S10
+ RECHTS -> S12
+-> S11
S12:= LINKS -> S11
+ RECHTS -> S13
+-> S12
S13:= LINKS -> S12
+ RECHTS -> S14
+-> S13
S14:= LINKS -> S13
+ RECHTS -> S15
+-> S14
S15:= LINKS -> S14
+ RECHTS -> S16
+-> S15
S16:= LINKS -> S15
+ RECHTS -> S17
+-> S16
S17:= LINKS -> S16
+ RECHTS -> S18
+-> S17
S18:= LINKS -> S17
+ RECHTS -> S19
+-> S18
S19:= LINKS -> S18
+ RECHTS -> S0
+-> S19
;OUTPUT EQUATIONS
;WP1.TRST = OE
;WN1.TRST = OE
;WP2.TRST = OE
;WN2.TRST = OE
;WP3.TRST = OE
;WN3.TRST = OE
;WP4.TRST = OE
;WN4.TRST = OE
;WP5.TRST = OE
;WN5.TRST = OE
CONDITIONS
LINKS = LI_RE * ENA
SIMULATION
SETF /OE /CLOCK ENA
;SETF /OE CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
Had a closer look at your code and simulation tonight. Apparently you did
not want the all zeros at state S0. I know 22V10s have some provision to
initialize at power up but I don't remember the correct syntax. I did - and
still do - not like it either so I used to circumvent it by defining State 0
to be all zeros (or low or false) which is the "natural" value at power up.
So I changed your code by changing your S0 into S00, making a new S0 which
is all zeros and adding a state transistion S0 -> S00. The simulation now
looks like:
PAL22V10
Page : 1
WP1 LLHHHHHHLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLHHHHHHHHHHHHHHHHHHH
WN1 LLLLLLLLLLLHHHHHHHHHHHHHHHHHHHHHHHHHHHLLLLLLLLLLLLLLLLLLLLLL
WP2 LLLLLLLLLLLLLLLLLHHHHHHHHHHHHHHHHHHHHHHHHHHHLLLLLLLLLLLLLLLL
WN2 LLHHHHHHHHHHHHLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLHHHHHHHHHHHHH
WP3 LLHHHHHHHHHHHHHHHHHHLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLHHHHHHH
WN3 LLLLLLLLLLLLLLLLLLLLLLLHHHHHHHHHHHHHHHHHHHHHHHHHHHLLLLLLLLLL
WP4 LLLLLLLLLLLLLLLLLLLLLLLLLLLLLHHHHHHHHHHHHHHHHHHHHHHHHHHHLLLL
WN4 LLHHHHHHHHHHHHHHHHHHHHHHHHLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLH
WP5 LLLLLHHHHHHHHHHHHHHHHHHHHHHHHHHHLLLLLLLLLLLLLLLLLLLLLLLLLLLL
WN5 LLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLHHHHHHHHHHHHHHHHHHHHHHHHH
PAL22V10
Page : 2
WP1 HHHHHHHHLLLLLLLLLLLLLLLLLLLLLLLLLLLLL
WN2 HHHHHHHHHHHHHHLLLLLLLLLLLLLLLLLLLLLLL
WP3 HHHHHHHHHHHHHHHHHHHHLLLLLLLLLLLLLLLLL
WN4 HHHHHHHHHHHHHHHHHHHHHHHHHHLLLLLLLLLLL
WN5 HHLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLHH
Suppose this to be the behavior you want to see.
petrus bitbyter
petrus bitbyter
TITLE schritt5
PATTERN
REVISION 1
AUTHOR fsm
COMPANY mrt
DATE 12/10/09
INPUT
INPUT
INPUT
INPUT
PIN 12 GND ;
INPUT
INPUT
PIN 24 VCC ; INPUT
STATE
MOORE_MACHINE
/WN5
/WN5
/WN5
/WN5
/WN5
/WN5
/WN5
/WN5
/WN5
/WN5
/WN5
WN5
WN5
WN5
WN5
WN5
WN5
WN5
WN5
WN5
;TRANSITION
S0 := LINKS -> S19
+ RECHTS -> S1
+-> S0
S1 := LINKS -> S0
+ RECHTS -> S2
+-> S1
S2 := LINKS -> S1
+ RECHTS -> S3
+-> S2
S3 := LINKS -> S2
+ RECHTS -> S4
+-> S3
S4 := LINKS -> S3
+ RECHTS -> S5
+-> S4
S5 := LINKS -> S4
+ RECHTS -> S6
+-> S5
S6 := LINKS -> S5
+ RECHTS -> S7
+-> S6
S7 := LINKS -> S6
+ RECHTS -> S8
+-> S7
S8 := LINKS -> S7
+ RECHTS -> S9
+-> S8
S9 := LINKS -> S8
+ RECHTS -> S10
+-> S9
S10:= LINKS -> S9
+ RECHTS -> S11
+-> S10
S11:= LINKS -> S10
+ RECHTS -> S12
+-> S11
S12:= LINKS -> S11
+ RECHTS -> S13
+-> S12
S13:= LINKS -> S12
+ RECHTS -> S14
+-> S13
S14:= LINKS -> S13
+ RECHTS -> S15
+-> S14
S15:= LINKS -> S14
+ RECHTS -> S16
+-> S15
S16:= LINKS -> S15
+ RECHTS -> S17
+-> S16
S17:= LINKS -> S16
+ RECHTS -> S18
+-> S17
S18:= LINKS -> S17
+ RECHTS -> S19
+-> S18
S19:= LINKS -> S18
+ RECHTS -> S0
+-> S19
;OUTPUT EQUATIONS
;WP1.TRST = OE
;WN1.TRST = OE
;WP2.TRST = OE
;WN2.TRST = OE
;WP3.TRST = OE
;WN3.TRST = OE
;WP4.TRST = OE
;WN4.TRST = OE
;WP5.TRST = OE
;WN5.TRST = OE
CONDITIONS
LINKS = LI_RE * ENA
SIMULATION
SETF /OE /CLOCK ENA
;SETF /OE CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
CLOCKF CLOCK
Due to the eternal "experimental" phase of the newsserver of my ISP, I
cannot see my own postings from time to time. Not the normal way that is.
Looking them up in Google Groups makes me see the mess that's made by
proportional spacing. So use a fixed font to look at the simulation results.
petrus bitbyter
F
Frank-Stefan Müller
petrus bitbyter
Hi Petrus,
I think you got it!!!!!!!!!!
Many thanks to you and all the other folks that tried to help me!
Frank from Karlsruhe / Germany
