Panasonic DECT on Hook inactivity Timeout
Martin Riddle
I have a KX-TG7641 DECT phone that works pretty good. I just discovered
it can pre dial an area code!, great for FIOS.
But, one problem is that it is easy to leave it on hook if you don't
press OFF.
This is kind of silly, I looked through the manual and don't see a
timeout for it at all. Did I miss something?
Perhaps I should add a one shot triggered by voice activity that would
send a pulse to the OFF button if its left on Hook.
Cheers
Phil Allison
"Martin Riddle"
But, one problem is that it is easy to leave it on hook if you don't press
OFF.
** The term "on-hook" means the phone is off and waiting for a call.
This is kind of silly, I looked through the manual and don't see a timeout
** All the cordless phones I have seen are the same.
You have to push "OFF" or put them in the charging cradle to get an "
on-hook" condition.
.... Phil
Martin Riddle
Phil Allison said:
"Martin Riddle"
on-hook" condition.
... Phil
Thanks, I meant Off-hook. Still, if you don’t place it in the charging
cradle, it may never go on-hook for hours.
Cheers
Martin Brown
It does eventually though when it runs out of battery power.
It seems to me like the phone could sensibly drop the line after 10
minutes or so with no sounds on either end.
I once had a very annoying early pre-DECT wireless phone which did not
drop the line if you put it back in the charging cradle without first
pressing the red end_call button. It was a disaster.
It also had lousy range in a brick walled house and the thermal fax
paper for the base station was extortionately priced into the bargain.
This was the final straw after junk faxes became all the rage.
