Panasonic Monitor SL90 no green
G.M. Durrence
While using my computer I suddenly lost the green color on my
Panasonic SL90 monitor. Can anyone suggest where to start checking,
or does anyone have a schematic for this monitor?
thanks
G.M. Durrence
(To reply remove -nospam)
N
Newfdog
thanks
G.M. Durrence
Faulty cable or connector maybe?
G.M. Durrence
Checked all that, also checked all ribbon cable connectors. Even the
menu doesn't have green so this eliminates cables and connectors. I
also made sure the CRT was socketed well. I suspect an internal CRT
problem but would like to test voltages on the CRT before discarding
it I but need a schematic.
G.M. Durrence
(to reply remove -nospam from address)
N
Newfdog
change the green drive wire, at the crt socket, with one of the other
colors and see if the green comes up. If it does then the crt is
probably ok.
Dave D
You don't need a schematic for that. You have three identical video circuits
so comparing voltages, preferably with a grayscale or white display on the
screen at the time, should be straightforward enough. If the green channel
measurements differ significantly from the others, chances are there's a bad
component on the CRT base PCB, ie video amp IC, open resistor, bad driver
transistor etc. It could also be a cracked solder joint, particularly on the
CRT socket. If the R, G and B cathode pins on the CRT are all giving similar
readings, then the green gun on the CRT has probably failed
catastrophically- it happens sometimes.
There's freeware pattern generators on the web which will display
appropriate patterns to help you.
Tom MacIntyre
That's the first thing I'd check.
Green is the closest pin to the left hand side facing, so it could
even be that the cable connector is not screwed in sufficiently.
Tom
Tom MacIntyre
Tom
I
G.M. Durrence
