Pancake coil winding
Spehro Pefhany
How are flat spiral (pancake) coils wound? How does the machine
differ from a conventional computer controlled winding machine?
Best regards,
Spehro Pefhany
Tim Shoppa
Isn't it just the degenerate case of 1 turn per layer?
But the ridiculous aspect ratio (height of turns : width of turns way
way bigger than one) will require some sort of bobbin wall.
I don't know much about "conventional computer controlled winding
machines" but have run hand-driven Morris coil winders.
Tim.
Terry Given
Tim.
do they dance with swords?
Cheers
Terry
Spehro Pefhany
No! More like one layer per turn-- but how do they get it to stay in
place?
Tim.
Best regards,
Spehro Pefhany
Jim Thompson
place?
[snip]
Chewing gum ?:)
...Jim Thompson
Ecnerwal
place?
Presumably with a bobbin. If you're seeing examples with no bobbin, then
they were wound with a bobbin (or the moral equivalent - call it a coil
former, if you like) and then probably varnished or epoxied, IMHO.
John Popelish
place?
Cotton covered and soaked with tacky wax.
place?
They might be using self-bonding wire, with comes with a layer of
thermosetting adhesive on top of the enamel; you wind the coil, then
run a carefully calculated current through the coil to get it hot
enough to set the adhesive,then take it out of the bobbin - the
application notes specify the kind of bobbin materials you can get
away with and the sort of release agents you have to use on the bobbin
so that you can take it out of the bobbin.
Most of the people I've talked with who have built self-supporting
coils didn't know about self-bonding wire and used slow-setting epoxy
resin. Here's the first useful web-site that I found with a quick
google.
http://www.mwswire.com/bond1.htm
Spehro Pefhany
On Mon, 3 Mar 2008 16:38:13 -0800 (PST), the renowned
google.
Thanks, Bill, that's very useful information. I think I see how to do
it now.
Best regards,
Spehro Pefhany
Michael A. Terrell
place?
Coil dope? That or hard wax. Those are the only two I've seen used.
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
Robert Baer
Best regards,
Spehro Pefhany
Why not make a PCB with a spiral path?
Robert Baer
place?
Best regards,
Spehro Pefhany
A type of glue seems to be used; applied to the wire feeding into the
coil.
Michael A. Terrell
Robert said:
How tacky? The wax was more tacky than my dumb jokes...
Not possible.
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
JosephKK
Best regards,
Spehro Pefhany
Currently it is often done with PWB processes (selective plating or
etching). Previously (about 60 years ago) it was done with litz wire
and glue.
Spehro Pefhany
etching).
That's not really winding-- and I'm not sure that PWB is practical for
relatively small quantities of coils made with exotic alloys.
Best regards,
Spehro Pefhany
