pdf to cadsoft eagle layer
i have a pcb trackside layout as a pdf file
i want to mod it
is it possible to convert this pdf file into a cadsoft eagle layer
i am sure someone must ve done this because - i am sure - no
self-respecting hobbyist ever uses anything as is where is
may be like harley - u just customize it
thx
H
Hal Murray
i want to mod it
I haven't done it, but it might not be too hard. I'd start
with converting the pdf to postscript, then edit that to
remove all the wrappers leaving just the line drawing commands.
Then write a script to turn that into an Eagle script.
Robert Roland
Eagle contains a ULP for importing a BMP bitmap. It is called
"import-bmp.ulp".
Getting the PDF to BMP could be done with a simple screenshot, but you
may have to fiddle with the scaling to get the size right.
I'm sure there are better ways to convert from PDF to BMP.
i want to mod it
thx
Is Eagle able to import dxf?
If yes then first convert the pdf to dxf, there are a number of
programs for this and then import it to eagle.
