Philips 41JP20 shutdown
James Sweet
Ok I'm back again with this pesky thing. Finally got the replacement Diemen
flyback, installed it, set came up but HV was about 8kv. Realized pins 1 and
3 need to be swapped for it to be wired as in the schematic, do that and set
comes up more or less normal. Now the bad news, I shut it off, unplugged it,
and put in the rest of the screws holding the power board in, plug it in and
turn it on, it fires up for a moment then shuts down. Monitored the HV,
fired it up again, HV comes up normal for a moment before relay clicks and
the set shuts down. I'm at my wit's end with this thing, what things can
cause shutdown with this set and where do I start?
techforce
Could be bad solder on the power board that when screwed down cause bad
connection. The Really old NAP's had bad solder Feed-thru's on the old
Boards, and sometimes even on the AC Line Terminals, causing the Flyback to
fail because it would be overheating. I would go through all the solder
everywhere since its an older set.
Diemen
and
set
it,
and
James Sweet
Already did that the first time I fixed it before the flyback failed, guess
I can go through it again though.
techforce
The fact you said it changed when everything was buttoned up would tell me
it has something to do with that action. Try Running it un-buttoned, and
Flex / Vibrate the boards in question.
Flyback
| to
guess
James Sweet
Yeah, though I also thought that perhaps the power cycle caused something to
pop, I'll have to go through it again.
Similar threads
Replies
5
2K
James Sweet
Replies
5
2K
John Del
Replies
4
1K
James Sweet
Replies
1K
techforce
Replies
5
1K
Jason D.
