Philips Digital Rerrestrial Receiver DTR500/05
N
newbee
Hi all,
The Digital Receiver would not switch on. I opened it up, and there is
I presume to be Fuse labeled F1 with the following marking on it :
CQ MET T2A 250V.
Am I correct in assuming it is a fuse, and if it is, where can I get
it in UK.
Thanks for your help.
Arfa Daily
newbee said:
Hi all,
CQ MET T2A 250V.
it in UK.
It is a 2 amp fuse with a "T" - that is time delay - rating. FWIW, if it is
the mains power fuse in a switchmode power supply, it is highly unlikely
that it will be the only problem. You can get one from any Maplin's store.
It is a very common value. Its size will be 20mm.
Arfa
