Mike
- Jan 1, 1970
- 0
I ran into one of these with a loud chirp-chirp of an over-loaded power
supply.
I took it apart and looked at the main board, and i seen where the fluid had
leaked all over it. not real bad, but it was pretty evident. so like i do
every other board, i removed it, and sprayed it down with hot water and
baked it at 175-200F for about two hours.
then let it cool down, and i checked the HOT and HV out transistors, and
they are fine.
hooked it all back up, and it still chirps. i checked all secondary diodes
and capacitors on the power supply and they are fine. ESR is fine. however
the main input filter cap on the module was bubbled up, so i replaced all 3
470uf at 200v caps. to make sure. they ESR checked fine, but that didnt mean
anything.
Still chirps. I removed plug 1516 that feeds power to the STK convergence
amplifier, it still chirped. so something has shorted somewhere in the main
HV/sweep/power supply module where the fluid leaked. didnt leak anywhere
else, no residue left behind.
any ideas? or am i stuck replacing the entire sweep/power module?
supply.
they are fine.
anything.
