Philips/Magnavox TV Schematics
  • Thread starter Paul Hovnanian P.E.
  • Start date
Paul Hovnanian P.E.
I have an inoperative Philips/Magnavox TV set and no schematics. Where
can one go to find/download/purchase schematics and maintenance
documentation?
I think it took a hit a few months back when we had a power outage. One
of the components let all of its smake out, but upon opening the set up,
its not evident which one. Nothing works (not even the pilot LED).
Its a chassis no. 25B800-7562
Sofie
Paul:
The schematics may be of little help unless you first can do some basic
troubleshooting and testing without them. There are NO step by step
troubleshooting procedures and the schematics are only most useful to those
who are experienced in television repair. A dead set due to a power surge
is usually one of the simpler repair scenarios.
Obvious first steps after your visual inspection would be dust off your DMM
and to test the power supply components and look for properly regulated B+,
in addition you should test the HOT to see if it is shorted and test for
other faulty components in that area of the cicuitry.
You may want to go to the website for this newsgroup at
www.repairfaq.org
there, with some of your search time, you will find a weath of repair,
troubleshooting, testing and safety information.
Best Regards,
Daniel Sofie
Electronics Supply & Repair
Paul Hovnanian P.E.
Sofie said:
Paul:
I've done quite a bit of electronics repair (and a little bit of TV
repair), and I wouldn't start poking around in something unless I had
some idea of what sort of circuit I was looking at.
I'd much rather rely on a schematic than trying to trace the power
supply around the traces of the main board.
You do not need a schematic or service manual to check and test the
components that Sofie indicated in his reply post. As he said, "dust
off your DMM ........."
electrictym
F
Franc Zabkar
documentation?
It appears to be available here for $10:
http://www.sharefx.com/archive2.asp?offset=30500
- Franc Zabkar
Paul Hovnanian P.E.
Try answering the question originally posted. That is, "where can one
obtain a schematic", not "do I need one".
I'd much rather have one in hand while searching for faults. I don't
repair TV sets as a profession.
clfe
Paul Hovnanian P.E. said:
Thanks. It appears to be $10 for a one month membership. I'll grab
schematics for all my miscellaneous gizmos.
THANKS! I may check that out myself. I've got a few things here I could sure
use a schematic for to finish up.
Lou
