philips pm 3305 oscilloscope question
max
Hi I have this scope and all power outputs half volts low than its
originally should.After checking all components i found that transformer
windings is shorted.do you know any companies who can re-wind the
transformer.Prefer companies in california.Thanks
W
whit3rd
      windings is shorted.do you know any companies who can re-windthe
Check the external wiring carefully: remember, the oscilloscope is
a vacuum tube device, it has high voltage windings and odd
requirements
for HV isolation of some of the windings. If you don't have a LOT
of data, rewinding it could be a disappointment.
Usually, a shorted winding gets hot; if it's really 'half volts'
that is the issue, look for a 110/220V selection switch.
max
requirements
switch is ok because input 30v ac is fine.
the transformer provide the high voltage and I think this transformer is
bad.Not always if the windings shorted transformer can be hot.I
disconnect the output power completely from logic and other boards of
scope.Still the same problem.Check all components in power supply
circuits.They all fine.Replaced some caps with losing value and
resistance ESR.Still problem exist.Hearing hard whistle from switching
transformer.Thanks
