Philips PM-3323 DSO Blowing Fuses
Jim Attfield
Hoping for a schematic of the PSU section (which is a switcher) so I
can start troubleshooting. Blows mains fuse the instant it is switched
on, something has shorted out in the PSU.
Jim
Jean-Yves
Jim
you may have a resistor or some diodes shorted, surely one or more
diode..
easy to check with a multimeter...
verify all big resistors ans all diodes as you can have more than one
shorted...
also check the main transistor which is probably shorted too.
Jim Attfield
diode..
shorted...
Thanks, that's what I plan to do but thought I'd start a trawl for
info/schematics anyhow. It's a bit more complex than normal as the EHT
supply seems linked to the main switcher as well.
Jim
Jean-Yves
Jim
what is the integrated circuit assuring the oscilator function in your
supply ?
Jim Attfield
supply ?
I don't know yet, I have still to work out how to disconnect the
on/off mechanism - the rod to the front panel goes through the PCB.
Jim
F
Fred Bartoli
Jim
A few years ago I reversed the PM3320A PSU. I still have the schematics, but
looking at it I didn't completly finished the work.
AFAIR it finally was the EHT transistor that was fried and made the main PSU
have vapors.
The 3320 and 3323 share a lot and almost surely have identical supplies.
Even if the schematics isn't completly finished (maybe up to 95%), it'll be
useful.
I send you a copy.
Joe Soap
In response to what Fred Bartoli
schematics, but looking at it I didn't completly finished the work.
main PSU have vapors.
supplies. Even if the schematics isn't completly finished (maybe up to
95%), it'll be useful.
I send you a copy.
PM3335 manual and circuits here:
ftp://bama.edebris.com/bama/philips/pm3335/PHILIPS%20PM3335-37-SM.djvu
Jim Attfield
Thanks anyway, but I was after PM3323 and nothing there is close
enough I'm afraid.
Jim
