Philips TV model 20PT6245/37, Vertical Deflection Problem
Brad
I have a Philips TV model 20PT6245/37 (mfg 05/05) in my
service shop with a loss of vertical deflection. I do not have SM.
For a moment after the TV is turned on, there is some vertical deflection,
but it collapsed into a single horizontal line in the middle.
I checked solder joints at the vertical IC, resoldered them anyway, but
this had no effect. Note: I soldered other joints too. Flexing and tapping
on mother board has no effect.
I couldn't find pin out info on the vertical IC AN7225N on the
web so I could make additional tests.
Thanks in advance, Brad
Before you type your password, credit card number, etc.,
be sure there is no active keystroke logger (spyware) in your PC.
b
scan coil connections?
Jamie
This may sound like an asinine statement how ever, with the weak
diagnostics described in the original post, how can one claim to be
a service repair man ?
What happen to the days of using component cooler on suspected parts
that obvious work at first, like in this post.
How about a service schematic, scope, DMM, Cap tester, ESR etc...
oh well..
http://webpages.charter.net/jamie_5"
