H
hepcatbrandon
- Jan 1, 1970
- 0
Hi everyone. I've just begun to learn about electronics and wanted to
try my hands at making a diverter (or rather a variation on a design
that I found), and I could use some help. The purpose of this circuit
is to connect two phone lines together so that when you call LINE 1
you get the dial tone of LINE 2 and can send DTMF and talk just as if
you had dialed out of LINE 2 directly. I appologize in advance for my
butt-ugly illustrations (see links) and general newbiness; the
drawings are meant to just show the basic logic, as that's enough for
me to worry about at the moment.
This is the first sketch I came up with:
To explain: In the position shown, both lines 1 and 2 are "on hook". I
dial up the number for LINE 1, the CO sends AC (ringing) current to
line 1 and the capacitor allows current to flow into the full wave
bridge rectifier, sending DC through the relay.
This closes both circuits in LINES 1 and 2, LINE 1 stops "ringing" and
allows DC to flow through LINE 1 and through LINE 2. Now it is LINE 2
that is keeping the relay open. Both lines are now "off hook".
The gold blotch represents the undefined connection between the two
lines that is the purpose of the circuit. I have been trying to find
information about DC coupling but it all seems very complicated. The
design that I initially found used a 600ohm-600ohm transformer, but is
there an easier way? what would happen if you connected them with a
bit of wire?
Now when the call is completed and whoever LINE 2 calls hangs up, the
CO will initiate a polarity reversal on LINE 2 that will cause the
circuit to collapse and reset. There is a problem if LINE 2 dials
something that never hangs up, however...
Which leads me to v0.2:
Now this may be crazy, I don't know. But in this design, when the
relay is thrown, LINES 1 and 2 are connected in a figure eight or
infinity symbol shape, with RING of LINE 1 flowing into TIP of LINE 2
and vice versa. This way, a polarity reversal on either end will reset
the circuit and I don't have to learn about coupling.
Does either design make sense? If not why? Any advice you can give me,
even to tell me what to go about reading into would be great.
bit of wire?
