Phono Jack deep nuts?
DonMack
Anyone know the name or a supplier of nuts for phono jacks that "deep". That
is, the phono jack itself doesn't protrude through the chassis and the nut
reaches inside the chassis to mate
Phil Allison
"DonMack"
** Disambiguation required.
1/4 inch phone jack ?
1/8 inch mini jack ?
RCA jack ??
that "deep". That
** I can only imagine you are alluding to 1/4 inch jack sockets with chrome
threaded inserts.
http://cdn.sigma.octopart.com/580592/image/Cliff-S4BNB.jpg
..... Phil
DonMack
"Martin Riddle" wrote in message
That is, the phono jack itself doesn't protrude through the chassis and
the nut reaches inside the chassis to mate
Try www.switchcraft.com
This?
<http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=SC1035-ND>
No, it is a nut with internal threads. Essentially a cylinder, maybe about
1/2" long with internal threads and a flange on one end. It sorta looks
like the digikey one but it is simply a "nut" with internal threads.. It's
used when the phono jack's threads do not stick outside for a simple nut.
http://www.switchcraft.com/productsummary.aspx?Parent=580
used on when the phono jack is mounted so that the threads do not extend
outside the chassis. I've seen them rarely but they did exist at one time.
