Photocopy without fusing the toner to paper
aeg olympia
I wonder if anyone could provide any advice.
I want to use the copier in a novel way to help put images on ceramics.
To do this I need to get the image out without the toner being fused to
the paper, I can then transfer the toner to the clay and after firing
the image appears!
I have disconnected the power to the heat roller but then the copier
refuses to work.
The copier is an old AEG Olympia Omega 1210Z.
I'm sure there must be a way of overriding this failsafe device but
have not been able to work it out so far.
I would really appreciate it if anyone had any ideas how i could do
this.
mc
Don't modify the copier. Instead, do a Google search for the press-and-peel
(toner-transfer) method of making printed circuit boards. That involves
Xeroxing or laser-printing onto glossy paper, then ironing the toner onto
another surface -- in our case a printed circuit board, but it could equally
well be a smooth ceramic surface.
Bart Bervoets
If you have to modify the copier, how about extending the wires that go to
the element and placing the element outside the machine
to trick the machine in thinking it's there?
Just my 2 cents.
Bart Bervoets
James Sweet
Just my 2 cents.
Bart Bervoets
The trick is not in keeping the lamp connected, it's fooling the
temperature sensor into thinking the roller is hot. Variable resistor
should be able to do this.
James Thompson
the image appears!
refuses to work.
this.
Have you tried using an ink jet printer. That way you can play with some
color. You would just wet the clay and wrap the printed paper on it so the
ink infuses to the clay. Or maybe the ink would just burn off, I have no
idea. But the toner way you are thinking of, may be hard to keep correct on
the paper. One tiny jar and the toner would shake off the paper or smear.
Still at firing temp you the clay, the toner may just burn off since it is
just plastic powder. Hmmm
N
N Cook
agreed but you would probably need to have a rough idea of the resistance
cold and hot as having the off/"hot" resistance at switch on may force an
error again. Also assuming the heated roller is on the top disconnect the
springs to lower roller, add a couple of finger deflectors at the edges so
the paper passes through the gap without the toner latent image touching the
roller.
